Flashing AFS off after installing after market HID
Old 05-10-10, 01:00 PM
Kidlat
Kidlat's Avatar
Unhappy Flashing AFS off after installing after market HID
First, my problem was my right headlight is turning off by it self after I start the engine. I went to a ExactMotor sports and they said it was the ballast problem and they recommend to install the aftermarket HID kit that comes w/ ballast. Reason for that is because the stock ballast is installed in the headlight assembly and the only fix is to replace the whole headlight assembly and that will cost me around $1500 per headlight. So I decided to get the HID kit on both side so that incase something happen with the ballast all I need to change is the ballast. The kit is only around $150 each. Then after they install it and start driving my car at night the AFS OFF start flashing.
Now, is there anybody out there had the same problem or is there any fix for this problem beside buying a 2 brand new headlight assembly? ExactMotor sports don't know what causing the AFS OFF flashing so I will not bring my car there ever again.
Old 05-10-10, 01:44 PM
acefalcon2
acefalcon2's Avatar
if your car is in warranty you can just go the Dealership and get it changed... on top of that... OEM Ballasts rarely do fail... try changing the bulbs and see whether they're faulty... getting a ballast at $150 each is itself a ripoff... xenondepot one of the best HID companies in the vendor section sells one less than that... naturally if you use a aftermarket HID kit.... the AFS would not work... so yeah... if you're still in warranty get it to the dealer right away... take out those aftermarket kits first though
Andre
Old 05-10-10, 02:14 PM
alan003
alan003's Avatar
i think you can buy a used denso d4 ballast and have a lexus mechanic changed it for you if the ballast has failed
Old 05-10-10, 02:27 PM
king06
king06's Avatar
you can install oem ballasts yourself if you want you dont have to replace the whole headlight whoever said that didnt know much about our cars. I replaced an OEM ballast on my car just gett them from ebay for about 50 bucks.
Old 05-10-10, 02:42 PM
laobo979
laobo979's Avatar
DId you try to turn the AFS switch on and off to see if it stay on? its on your dash display features
Old 05-10-10, 04:44 PM
Kidlat
Kidlat's Avatar
Thanks for all of your reply.. I decided to bring it to the dealership co'z I don't want to waste my time on going back and fort to ExactMotor sport that does not know about AFS and they don't give free rental car...
Word of advice don't go to ExactMotor sport unless its a mechanical issue because they don't know much about electronic stuff inside your car.. Such a waste of time!!!
Old 05-10-10, 04:50 PM
LexHes
LexHes's Avatar
Anything that malfunctions like that.. just bring it to the stealership for warranty.. They USUALLY dont hassle you much about it and they just fix it. Smart man..
Old 06-08-10, 03:49 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
EDIT - Sorry. I misread the original post.
Old 06-08-10, 06:54 PM
acefalcon2
acefalcon2's Avatar
steve,
to even have the AFS light to come one he has OEM ballasts... i am sure the OEM ones are not Low quality HID Kits
Andre
Old 06-09-10, 08:18 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Andre,
Correct. I misread the post.
Steve
Old 11-06-11, 09:13 AM
soparkar
soparkar's Avatar
Can you please let me know how your problem got solved? Did dealer put a new ballast in your headlight?
MWIS350
06-01-15 05:14 PM
GFM2Fitty
09-12-10 02:23 AM
Whitmanpc1
SC- 1st Gen (1992-2000)
05-19-04 11:32 AM
lexasgs400
05-08-01 03:11 PM
Quick Reply: Flashing AFS off after installing after market HID
