Will those wheels fit? START HERE.
Old 11-18-14, 12:48 AM
  #5101
mrAkana
mrAkana's Avatar
Originally Posted by aandyxp
I currently have a 2007 is350. My car is lowered by 2 inches on bc coilovers. I am currently looking at the Work cr kai 18x8.5 +38 offet 18x9.5 38 offset.
front 225/40 rear 255 / 40
My question is will i have any problems with rubbing and will i have to mod my fenders. please help.
I can't speak on fitment for the Work setup but from what I gathered when trying to get my fitment was that it wouldn't be an issue for your dimensions. Since the offset is close to factory of a +45, putting a +38 is putting you a 1/4" closer to the fender which would still give you plenty of room.
See what you could find in this two threads:
https://www.clublexus.com/forums/is-...ls-on-2is.html
https://www.clublexus.com/forums/is-...el-thread.html
My current setup is 18x10 +25 lowered on springs, 225/40 255/40 with occasional rubbing on harsh dips but I have no fender mods although I do plan on rolling the rears just a touch when I get my BC.
Attached Thumbnails Will those wheels fit?  START HERE.-80-20141101_145828_richtone_hdr_1__8afe792eb35dac848daba76c0b90ab9e024af03c.jpg
Old 11-18-14, 01:00 AM
  #5102
lysis250
lysis250's Avatar
I had Avant Garde M310 on my car size was 18x8.5 +35 in the front, 18x9.5 +40 in the rear. The front was very good the tears however could have been pushed out a little more for a more flush figment, with your +38 it will be very nice. I also ran 225/40/18 front and 255/40/18. I was lowered about 1 finger gap all around and didn't have any problems, however when I got my coil overs the previous owner was lower and with my wheels I rubbed in the front on turns, only took it for a spin once at that height and raised the car right after that.
Old 11-18-14, 02:44 AM
  #5103
aandyxp
aandyxp's Avatar
Thank you very much. It's just I have no finger gap for my rears and wonder if the 18x9.5 will poke out too much.
Old 11-18-14, 02:47 AM
  #5104
aandyxp
aandyxp's Avatar
Do you have a picture of how low you were ? People said I should be fine but it really depends on how low I am. I don't want it to rub on every turn
Old 11-18-14, 11:14 AM
  #5105
lysis250
lysis250's Avatar
Found one. I'm sure you will be fine, if you can imagine 1 finger gap between fender and top of tire.
Old 11-18-14, 01:43 PM
  #5106
aandyxp
aandyxp's Avatar
Attachment 347308
I'm guessing with the new wheels. It'll stick out more than stock wheels. My car is much lower so I'll have to raise it
Old 12-01-14, 09:27 PM
  #5107
woohoo72
woohoo72's Avatar
After driving in snow with my IS 250 couple times. I am considering snow tires.
It has stock F 225/45/17 and R 245/45/17. Would 215/60/16 fit on my IS250?
It would be almost an inch larger in diameter on the front and a half an inch on the back.
Old 12-25-14, 10:02 AM
  #5108
ms2619
ms2619's Avatar
Found a really nice set of Vossen CV7s for a good price but the owner has 20x10.5 +45 all the way around...can this fit a 08 IS350 RWD lowered on h&r springs ?
Old 12-25-14, 11:40 AM
  #5109
jordannnx
jordannnx's Avatar
hey guys,
so I currently have a 2002 is300. I just bought 17x9 +25 offset rims, and I'm wondering what tires would be good to give me just a little stretched look?
I'm also lowered on BC coilovers BR type, no rolled fenders. hoping to find a look that will allow me keep my fenders unrolled. but if I have to, I can! let me know what's up.
Old 12-31-14, 01:01 AM
  #5110
albertgoq
albertgoq's Avatar
Originally Posted by Alwaysgolf
should clear the fronts no problem . maybe even considering doing 235/35 on the front and 255/35 on the rear .
How bout the rears on 18x9.5 +38 265 tire width?
would 255's stretch on 9.5 rims?
Old 01-07-15, 01:57 PM
  #5111
kwanye
kwanye's Avatar
Anyone know if I will have rubbing problems with 19x9.5 +20 and 19x10.5 +27? I'm also lowered about 2 inches on megan EZ's. Thanks in advance!
Old 01-08-15, 05:01 PM
  #5112
dyongg
dyongg's Avatar
I'm tucking about half my tire on 18 stock lobster claws. Can I fit these wheels with just a fender roll & possibly pull?
19x9.5 +22 with 225/35/19
19x10.5 +22 with 245/35/19
Thanks!
Old 01-09-15, 06:25 PM
  #5113
is25019
is25019's Avatar
hey i have a 2011 RWD is250, thinking of getting rims off this guy who has a AWD is250, setup is Forged Rims 18x9 +40, will this work or do i need to do a staggered setup, order wider rims in back, or just put wider tires in back with same rims?, new to this car thing wanna get it right
Old 01-10-15, 08:10 AM
  #5114
Sportskid1
Sportskid1's Avatar
Those should work for you as they are not a very aggressive offsets. I am running a square setup on my is350 with 18X8.5 +35 running 255/35/18 on all corners. No rubbing and seems to work great. I am lowered to about 1.5 fingergap.
Old 01-10-15, 10:36 AM
  #5115
nfordhk
nfordhk's Avatar
Can someone give me advice on:
2011 IS350 FSport
19x10 Offset +2 3.5" Lip
19x11 Offset +9 4.5" Lip
I have an Fsport big brake kit.
Quick Reply: Will those wheels fit? START HERE.
