How to disable VSC & TRAC simultaneously on 2007 GS & IS
Old 09-17-06, 08:03 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Exclamation How to disable VSC & TRAC simultaneously on 2007 GS & IS
Commonly misreferenced as the VDIM Cutoff feature, this feature is applicable to 2007 IS & GS models. This will not work with 2006 IS & GS models. To disable VSC (Vehicle Skid Control) & TRAC (Traction Control) on a 2006 model, please refer to this method here:
2006 IS & GS - VSC & TRAC OFF
To disable TRAC & VSC simultaneously:
1. Press PUSH START to the ON position.
2. Hold the TRAC OFF button for 3 seconds.
3. Then you will see both the TRAC OFF & VSC OFF indicator light displayed on your dash cluster.
To disable TRAC only:
Step #1. Press the PUSH START to the ON position.
Step #2: Press the TRAC OFF BUTTON once.
Step #3:
The TRAC OFF dash indicator will turn on:
To reset these features to normal operation, you can simply restart the car or press the TRAC OFF button once to clear the system.
WARNING: Please use this feature at your own risk. This is solely for your information only. Club Lexus is not responsible for any malfunction, void of warranty or damage to your Lexus vehicle.
seve7
03-15-21 03:12 PM
mhabrar
11-05-17 11:43 PM
Maher331
06-19-17 02:53 PM
intls
31
01-25-08 03:47 AM
MoreMGD32
03-25-07 07:07 PM
Quick Reply: How to disable VSC & TRAC simultaneously on 2007 GS & IS
