Tons of caliper rattles - no anti-rattle clips in my is
Old 05-28-06, 08:34 AM
LexusSara
LexusSara's Avatar
Default Tons of caliper rattles - no anti-rattle clips in my is
can't believe the got cheap on the brake pad and calipers
this is where all my noise is comming from when I go over the midest bumps
anyone else
i just confirmed this, my calipers are loose
Old 05-28-06, 11:02 AM
Tammy
Tammy's Avatar
Suggest a trip to your Lexus parts department to determine the correct clips and shims. Their computer could display the complete assembly for you.
The bolts holding on the caliper are loose? (17mm bolt head) They are tightened on the front caliper to 86 Ft Lbs.
Old 05-28-06, 11:32 AM
uschardcor
uschardcor's Avatar
i've had a feeling lately that the 2is might be the car that shows where lexus/toyotas manufacturing process is getting a little more slack than typical. toyota has addressed it saying they are trying to expand production capacity without error, and its a difficult task. then again, its a first year car...
i hope any changes they make on the 07 to minor imperfections (a la rear view shaking) will be upgradeable on the 06
Old 05-28-06, 11:42 AM
monkeyfarm
monkeyfarm's Avatar
I think you might be a little confused. If the portion of the caliper that's solidly mounted is loose, then aside from a dangerous situation, you just need to tighten the mounting bolts.
However, since you're also referring to anti-rattle shims, which have absolutely nothing to do with how the calipers are mounted, I'm assuming what you really mean are that the pads are rattling.
Old 05-28-06, 01:21 PM
LexusSara
LexusSara's Avatar
Something in each of the rear calipers is rattleing over bumps. We just check the suspension and everything is tight... yeah I think too the pad have a lot to do with it
what should I do, anyone
Old 05-28-06, 09:59 PM
lexy250
lexy250's Avatar
how many miles have you put on your car sara? i have put on just over 3500 miles and no longer have the noise...
Old 05-29-06, 04:57 AM
LexusSara
LexusSara's Avatar
I have 2000 now, mmm go away...
did you do it in the rears only, kinda like keys in a tin can sound...why would it go away?
I think it would get worst.
thanks
Old 05-29-06, 06:11 AM
chuckb
chuckb's Avatar
why not just bring it to the dealer and take advantage of your zero cost bumper to bumper warranty?
Old 05-29-06, 07:32 AM
LexusSara
LexusSara's Avatar
Our local dealer does not anyone I think is good.
I think I will call around to other Lexus dealers and ask
thanks
DaEvilG
IS F (2008-2014)
14
04-29-16 11:25 AM
morris
Suspension and Brakes
10-24-06 09:14 AM
pinoybboy
05-02-06 03:51 AM
Quick Reply: Tons of caliper rattles - no anti-rattle clips in my is
