IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
01 is300 throtel issues
Old 08-07-15, 02:49 PM
Militaryca
Militaryca's Avatar
Default 01 is300 throtel issues
I keep getting codes p0121, p1120, p1121, p1128 I have replaced the TPS and The APPS but I keep getting one of these codes at random today I got the p0121 twice then the p1128 6 hrs later should I replace the last item on the list the throttle control motor
Old 06-06-16, 06:59 AM
Bails
Bails's Avatar
Im in the same boat as you it seems. I have got all those codes. Ive replaced the tps apps and maf as well as spark plugs/wires.
I have my tps set to .69vdc. Have you had any luck finding a solution?
Old 06-30-16, 11:21 AM
allturbo98
allturbo98's Avatar
I had the same problem before. I changed all the same items too. The problem would go away for a bit then return. I was going to trace the wires back from the APPS to the ECU and run new wires because I was that annoyed with it. I ended up looking at the wires from the APPS and going back about 6 inches and noticed that the wires were spliced in. I also noticed that the heat shrink that was over the splices were old and I could see the wires under it. I ended up re-soldering the connections and putting on new heat shrink. Haven't had a problem since.
Old 06-30-16, 01:08 PM
Bails
Bails's Avatar
After adjusting my tps several times i finally noticed that the new tps wasnt as snug at the connector as the original. I put the original tps back on and set it so warm engine idle was about 750 with the new maf and new apps and it has been running good for a couple weeks now.
SeanHIS300
Performance
11-26-18 07:10 AM
B3ND3R817
04-14-18 11:01 AM
DazHavoc
08-10-17 09:49 AM
IIbad4u
09-07-15 03:07 PM
jmf300
Florida Lexus Club
18
01-07-12 10:57 AM
Quick Reply: 01 is300 throtel issues
