IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Help!!! 2001 IS300 keeps shutting off.
Old 04-05-14, 07:55 PM
Bbohnsack
Bbohnsack's Avatar
Default Help!!! 2001 IS300 keeps shutting off.
So here is a run down...first thing that happens is that is feels like the power steering is going out when I'm parking or pulling out of a parking spot. Then it will run for a little while, then all the dashboard lights (abs, oil, battery, etc) come on. Then the car starts to sputter, then sounds like it's going to stall.
I have checked the battery terminals, replaced the battery and the alternator. This has happened 3 times. We are able to charge the battery...it runs fine for a little while then starts all over again.
At this point I'm at a loss. If anyone has any input it would be greatly appreciated.
Old 04-07-14, 09:02 AM
EZP
EZP's Avatar
I would start with the basic. Check all grounds, make sure they are clean, check all fuses... Make sure to check the integrity of the wires going to and connecting to the alternator.
Bbohnsack
Maintenance
04-12-14 01:24 AM
lotusing
12-18-11 03:17 PM
Teahupoo
12-18-11 06:55 AM
00lexondub
07-10-05 10:00 PM
jewelerz
Maintenance
11-01-03 01:15 PM
Quick Reply: Help!!! 2001 IS300 keeps shutting off.
