abs light
abs light
How can I find out which sensor is bad? I just fixed the p/s/f cause it was cut. Is there a way to reset this abs light? I'm pretty new to the the IS realm. plz help.
Pulled the following codes from the dio port in the car:
p0057
p0420
what do they mean and how can I fix it?
p0057
p0420
I'm not familiar with the 1st gen IS so I'm not sure if the diagnostic process is the same as my 2GS3.
I used the diagnostic port in the engine bay to pull the codes for my ABS using the Tc and E1 connectors. With this method I was able the pinpoint the bad ABS sensor and re-solder it.
Disclaimer: This is only what I did. I will not be responsible if you fry your ECU or something important using this method.
