negative camber on stock height?
Does anyone else have this problem? IS300 on stock height but has bad tire wear on the inside, especially on the rear tires... suggestions?
The 1IS have a stock setting to have a little negative camber. Go to a good alignment shop and have them zero out the camber a little and toe it in a little more as well. That should fix your alignment issues.
I have slight inner wear too and will be hopefully aligning and flipping them next month pending my finances.
RocketGuy3
Suspension and Brakes
24
06-13-10 01:14 PM
