IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
help! oil in coolant??
Old 12-22-14, 09:51 AM
mxinkid1
mxinkid1's Avatar
Default help! oil in coolant??
Ok guys I have a 2004 is300, manual transmission, 104k. I am getting oil I'm the coolant but absolutely no coolant in the oil and no over heating or running issues. Ideas?
Old 12-23-14, 07:07 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Pictures?
There is no engine oil cooler on the car, so cracked head or head gasket are the only real possible culprits.
Old 12-24-14, 11:24 AM
dsouthmia0
dsouthmia0's Avatar
Yup sounds like a head gasket
Old 12-30-14, 12:41 PM
BTrusty504
BTrusty504's Avatar
Head gasket no doubt.
Old 12-30-14, 12:55 PM
kornpeef
kornpeef's Avatar
head gasket for sure, but if you want 100% piece of mind do a leak down test.
Old 01-01-15, 08:25 PM
LocalIS300
LocalIS300's Avatar
Originally Posted by kornpeef
If you want 100% piece of mind do a leak down test.
Expect to spend a bunch of money to replace the head gasket. You should ask a mechanic to check the block over. Look at doing a compression test and leak down test. Has the engine been overheated and subsequently run for a decent period of time?
Brutus213
07-11-17 11:38 PM
ksullivan
12-27-10 11:19 AM
Gomer1
RX - 1st Gen (1999-2003)
09-26-10 07:41 AM
nghty89
GS - 1st Gen (1993-1997)
07-28-09 12:19 PM
ProfesrLEX
07-11-07 04:26 PM
Quick Reply: help! oil in coolant??
