Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
20% MPG Drop After Bridgestone Alenza
Old 01-25-15, 11:13 PM
gsenthil
gsenthil's Avatar
Default 20% MPG Drop After Bridgestone Alenza
At about 120k I changed the bald tires on my 2008 RX400h to Bridgestone Alenzas at Costco that seem to get high reviews here and elsewhere. However, the mpg as reported by the trip computer and the speedometer has gone down 20% consistently. I drive from Seattle to Portland regularly with the same driving pattern/cruise speeds. Earlier I would get 27mpg and now I get 23mpg. Also, when I drive 40-50mpg in local roads I would easily get 28-35mpg and I am finding it hard to achieve that.
I have a tire pressure gauge that is accurate to 0.1psi and I maintain all at 36psi I am running out of ideas of what else could go wrong either w the installation or the tires. Please help
Old 01-26-15, 07:36 AM
smassey321
smassey321's Avatar
What were the tires you replaced? I get 23 mpg with Michelin Latitudes driving I-5. With the same tires I got 26 mpg in Florida. The CA winter gas gas really kills me.
Old 01-26-15, 12:12 PM
gsenthil
gsenthil's Avatar
The older tires were Michelin Energy
No change in gas/geography- always fill from the same Costco location
Old 01-26-15, 01:16 PM
maseace
maseace's Avatar
MPG drop is to be expected when you switch from Low Rolling Resistance tires like the OEM, to non-LRR tires like the Alenza. Mine dropped about 3 MPG going to the Yokohama Parada Spec-X (great tires in every other regard), and I will definitely switch back to LRR tires next time. Looking at the Continental PureContact with EcoPlus Technology for my next tire.
Tirerack.com has an option to filter by LRR tires only.
Old 01-27-15, 09:46 AM
jakenbake
jakenbake's Avatar
I am needing new tires and probably going to go with Michelin Premier. They are supposed to be great with mileage. But either way it sounds like you get great mileage...I used to make the drive between Portland and Seattle a lot before I moved to Phoenix and I always only got about 25 MPG on I5. And in town I averaged about 21 MPG. Since being in Phoenix I have been averaging 23 MPG but I am sure that is due to flatter and smoother roads along with less stop and go.
Old 03-04-15, 05:59 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
are you using this one?
http://www.bridgestonetire.com/tire/...422-ecopia-eco
jkutti2000
ES - 5th Gen (2007-2012)
04-12-12 11:51 AM
sallydrive
02-19-12 04:31 PM
Number6
11-18-11 01:55 PM
LBCDan
07-09-10 07:48 PM
vmcgarve
Hybrid Technology
12
03-06-10 09:08 PM
Quick Reply: 20% MPG Drop After Bridgestone Alenza
