Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Water pump
Old 01-06-14, 04:58 PM
riwyle
riwyle's Avatar
Default Water pump
Took my 2006 RX400h, 70000 mi, in for module recall & they called me in to show me a pink buildup which they said is a water pump weepage. I saw a pretty good buildup. They want $1200 to change pump, including a new timing belt. Does this sound legitimate & and is it a fair Price?
Old 01-06-14, 06:06 PM
sgmstr
sgmstr's Avatar
It maybe leaking from intake gasket, which is a common issue for RX gasoline, but can't say whether it's common for Hybrids. if it is, it should cost you way less than $1,200. $1,200 from a dealer is very cheap, but expensive for an independent.
I'm getting my 04 RX330 waterpump and timing belt changed (with two idle pulleys) and I got a quote for $900 from my mechanic. All Lexus Parts.
Old 01-07-14, 06:58 PM
vjhig
vjhig's Avatar
Hi
The same thing happened to me! But mine is a 2007 with 46,800--(got it Nov '06) I am out of warranty but my service guy called corporate and they are going to cover half-- The timing belt is being done too.
Good luck
vj
Old 01-13-14, 05:29 PM
Allen580
Allen580's Avatar
Default Careful
When I had my recall done, they told me the same thing (water pump is leaking). I keep the car in my garage and know the smell of anti-freeze. I knew it was not leaking. I told him I did not want to have this work done and he never mentioned it again. When I got home I checked, which is hard to do, but I have a mirror on a swivel. It has now been another year and the water pump is still fine. I do not plan on ever going back to this dealer
Old 01-13-14, 09:07 PM
joedaddy1
joedaddy1's Avatar
same story with me.. but maybe it's leaking but just a small leak?
Harvey99
05-30-15 08:04 AM
WB03LS430
12-09-08 08:49 AM
KurtK
09-10-08 12:03 PM
zach
01-08-07 05:21 AM
sarcazm
08-28-05 12:07 PM
Quick Reply: Water pump
