Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Brake Pads on RX400h
Old 07-22-13, 09:31 PM
thomas1
thomas1's Avatar
Not compressing would make me nervous that the piston is seized. may be time for a new caliper.
Old 03-27-14, 07:57 AM
elfnumber1
elfnumber1's Avatar
Originally Posted by colinshots
"Successfully" changed pads and rotors on front and rear. Rear guide pins on calipers were a bit seized so replaced them too and all's good EXCEPT the rear driver side's (right, I'm in UK) rotor is showing that the pads are not contacting properly and after taking it all off again to ensure the slider and piston are definitely moving easily, it's still doing the same.
Looks to me like when the brakes are applied there's no pressure at that caliper's piston.
The three others work fine.
Any ideas on this one??
I admit that I haven't done full searches on this yet, but first thread I went into for brakes and rotors...sorry. Does anyone have rec's for rotors for the 2006 RX 400h? Want to replace all brakes and rotors because we just bought the car recently and the rear's will need to be changed in a few months.
Old 03-30-14, 09:13 PM
thomas1
thomas1's Avatar
I know your climate is harsher than mine, but the Brake rotors and pads last forever on this RXhybrid. Because of the regenerative brake system (electric) the wear on the conventional brakes is very slow.
Old 02-22-15, 10:26 AM
zmisst
zmisst's Avatar
How long have people driven before hearing the brake pad wear sensor on their 400hs? My prius went 150k on the original pads with still lots of life left -- then I sold it. Wondering about pad life with the 400h.
What mileage have you obtained before hearing the audible warning sensor built into the pad, or confirming with a real measurement of pad thickness? (just changing the pads because a dealer told you to based on mileage doesn't count).
I drive on the highway and almost never use hard braking so I mostly use gentle braking and use the regen of the 400h to make electricity instead of making brake dust.
"the front and rear brake pads should last well over 100,000 miles and might not need replacement for the life of the vehicle."
http://www.caranddriver.com/reviews/...ormance-page-2
Old 03-11-15, 02:32 PM
jakenbake
jakenbake's Avatar
I just traded in my 2006 last month. But I had the original brake pads until 115,000 miles. I hadn't hear the wear indicators yet but new they were toward the end of their life.
Old 06-21-18, 10:11 PM
thomas1
thomas1's Avatar
Ok folks just changed my pads for second time on front, they went 115k miles and the inside pads were definetly close to wear indicator. So next need to check rears. 227k on the vehicle.
Old 06-22-18, 08:46 AM
MellonC00
MellonC00's Avatar
do you think that's is about normal - 100K miles plus for pad wear? It seems about right for a hybrid......
Old 06-23-18, 05:20 PM
thomas1
thomas1's Avatar
I think 100k would probably be a safe bet, however remember I live in California which is easy on cars, no rust, salt etc.
Jafch1
GX - 1st Gen (2004-2009)
07-01-13 07:22 PM
hybridanim
Suspension and Brakes
04-05-11 05:22 PM
mel's-gs
07-27-09 10:17 AM
tocoolexus
SC- 1st Gen (1992-2000)
11-28-01 08:23 AM
933005spd
06-04-01 06:55 AM
Quick Reply: Brake Pads on RX400h
