Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
DIY RX 400h Oil Change - Official Manual
Old 04-05-11, 06:18 AM
prowler97
prowler97's Avatar
Thumbs up DIY RX 400h Oil Change - Official Manual
Attached below in PDF format is a step by step DIY oil change for 2006-2008 Lexus RX 400h.
The only thing I have a question on is the size of SST (Special Service Tool) 09228-07501 in step 3a. The SST is 64mm x 14 flute oil filter socket. You can buy one at any auto parts store for ~$5.
Once I get the OEM (Original Equipment Mfg) filter off I will be using a PureOne filter which uses a 76mm x 14 flute oil filter socket (Torque: 18 N·m or 13 ft·lbf).
Oil filter Part Numbers:
Toyota 90915-YZZG1
K&N HP-1002
Mobil 1 Model M1102
Purolator L10241 or PureOne PL10241
Bosch 3330.
As for Oil I am going to use Mobil 1 0W-20 Advanced Fuel Economy if I can find it?
File Type: pdf
Old 04-05-11, 06:46 AM
thomas1
thomas1's Avatar
Ive found that oil at Walmart....
Old 04-05-11, 10:36 AM
rcy
rcy's Avatar
0w20 is good. I use it in the winter. I plan to use it all year. However, I had a couple of jugs of 5w30 sitting in my garage, so I've been using 0w20 in the winter and 5w30 in the summer.
Torque - can't say I've ever torqued the filter or the drain bolt, and I highly doubt the guy at the dealership does it either...lol. However, if the filter is torqued on correctly, you should be able to remove it by hand anyway.
I've been using the Toyota filter (I like that the o-ring comes pre-lubed) but my most recent oil change (last week) I used a FRAM Xtended Guard which is THE ONLY Fram I would recommend (this one is well built, the other models...not so much).
Old 04-05-11, 12:06 PM
prowler97
prowler97's Avatar
You may find this link useful:
Oil Filters revealed: http://minimopar.knizefamily.net/oil...reference.html
It appears from my research on the internet that Toyota oil filters are made by Denso.
Old 04-05-11, 03:19 PM
rcy
rcy's Avatar
Seen it...it's from 1999 with an update in 2008 I think. Fram didn't even make an Xtended Guard back then (and again, I'll state that only the Xtended Guard is a decent filter by Fram).
Yes, Denso still makes Toyota filters, but I'd bet a good portion of those other filters are now being sourced by some other company. Case in point..(although it's not in that study) Honda filters used to be made by Filtech. Only the factory installed filters are Filtech now, the ones from the dealership are made by FRAM.
If you're interested in oil and filters, I'd suggest
www.bobistheoilguy.com
You can read till your eyes bleed, there's that much information there.
Old 04-11-11, 09:33 AM
prowler97
prowler97's Avatar
I found Mobile 1 0W-30 Advanced Fuel Economy at Walmart this weekend for $24.50 in 5 qt jug.
Does Lexus use full synthetic with dealer oil changes or just the regular oil?
Old 04-18-11, 05:52 AM
PLamarine
PLamarine's Avatar
0W-20 is the spec oil for the 2008 RX400h, and the dealer uses it, and it is always synthetic because that is all that is available in 0W-20.
Old 04-18-11, 07:52 AM
rcy
rcy's Avatar
Why don't you just go to the Toyota / Lexus dealer and buy 5 litres of the Toyota 0w20? It's good stuff.
Old 04-25-11, 06:31 AM
prowler97
prowler97's Avatar
Just an update. The OEM (Original Equipment Mfg) oil filter (Toyota part # 90915-YZZG1) uses a 64/65mm 14 flute oil filter socket. I picked one up at Pepboys for $5.
The Purolator L10241 or PureOne PL10241 oil filters use a 76mm 14 flute oil filter socket. which they have a pep boys also. It just so happens to be the same size oil filter wrench used on late model Mercedes Benz.
As for buying Toyota oil form the dealer; the reason Is I do not live close to a dealer and I don't feel like paying there marked up prices.
Old 04-25-11, 05:09 PM
PLamarine
PLamarine's Avatar
Same here. I get a 5 qt jug of Mobil 1 for 24.50 at Wal Mart and my filters i bought a case of OEM YZZG1 for a few dollars a piece off Ebay.
Old 04-26-11, 10:03 AM
prowler97
prowler97's Avatar
Attached below is a better DIY oil change instruction for the RX400h (also works for RX330 & RX350). This instuction includes photos and instructs how to turn off "MAINT REQD" message on the dash. Enjoy
File Type: pdf
clicc916 (08-02-22)
Old 04-26-11, 03:25 PM
rcy
rcy's Avatar
Nice write up/pictures. Damn, I envy you owners that don't have salt on the roads - everything stays rust free so much longer.
Old 04-27-11, 06:03 AM
prowler97
prowler97's Avatar
Yes, the cars stay prestine. I took my Florida car to Connecticut for one winter and it was amazing how fast it rusted.
BTW: I tried this electric oil extractor and it worked awesome! It makes the job so easy and clean.
http://www.youtube.com/watch?v=wBArv...layer_embedded
Old 04-27-11, 05:31 PM
PLamarine
PLamarine's Avatar
The spec oil for my 2008 is 0W-20. Might want to note in your write-up Brian.
Old 05-02-15, 02:38 PM
jooksing82
jooksing82's Avatar
Default Oil plug Gasket
Any one know the part number for the gasket?
Ebay yielded Toyota part# 9043012031 , Rock auto DORMAN Part # 095143
I haven't replaced mine in a while and thought I should.
Cb4h
06-13-23 12:32 PM
GRPFAN
RX - 3rd Gen (2010-2015)
11-28-11 06:32 PM
scout356
05-07-10 09:06 AM
gary1944
HS 250h Model (2010-2012)
04-14-10 01:49 PM
jim1792
03-09-10 04:22 AM
Quick Reply: DIY RX 400h Oil Change - Official Manual
