GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Best Diagnostic Scanner (code reader) for Lexus?
Old 01-26-15, 05:42 PM
LexRex
LexRex's Avatar
Got my replacement Techstream knockoff today. The first cable was defective and would not allow the settings to be changed. I kept the software unchanged for the replacement cable and this time it worked.
However this second cable was also defective. I noticed the light on the cable wasn't working initially so I had to hold the cable tightly in the USB port. (Switching USB ports did not help.) Then the Techstream would not connect to the car. I had to hold the USB plug in right AND hold it a bit to the side. It finally worked.
Bottom line is that these cables.must be made extremely cheaply. If you buy one and it does not work, send it back and get another. You'll see all kinds of posts on other forums where people are having errors or problems making it work. I'm convinced that it's a matter of poor quality control on the cables.
Old 03-26-15, 09:36 AM
Bgw70
Bgw70's Avatar
How many files are on the cd and what are the file sizes?
Or, what is the total data size of the disk?
Tks
Old 10-18-16, 11:23 AM
IanB2
IanB2's Avatar
Originally Posted by Gene01
Just be aware that at least some of the techstream packages will only run on a 32-bit OS.
The PC can be 64-bit, but the OS must be 32-bit.
This bit me in the *** when I went to program my new key, garage computer and laptop are both on Win10, must have been 64bit as the software wouldn't run on either. Luckily I have an old laptop for running MB STAR DAS software that runs winXP and worked for me, but took a long time to get it working.
Old 10-19-16, 09:27 AM
shadowmite
shadowmite's Avatar
There is a procedure to make it work fine on a modern 64 bit os. I use it on a win 10 64 bit tablet without any issues.
http://www.ft86club.com/forums/showthread.php?t=73034
Old 10-19-16, 11:40 AM
IanB2
IanB2's Avatar
Good info, I'll have to give it a try next time.
Old 10-21-16, 06:20 AM
chiph9
chiph9's Avatar
Make a complete backup of that computer. Image the drive if you can. Because you can't install XP from fresh (like if you had to buy a replacement laptop). Microsoft's product authentication servers (the "Genuine Windows" ones) won't issue a license any more for XP.
Chip H.
Lexmember
GS - 1st Gen (1993-1997)
03-28-17 01:45 PM
diverchris
05-01-14 01:20 PM
jerryparks
11-02-13 11:53 AM
-Future-
01-26-10 10:50 PM
Larry99
RX - 1st Gen (1999-2003)
08-10-03 05:05 PM
Quick Reply: Best Diagnostic Scanner (code reader) for Lexus?
