windshield wiper fluid frozen
Old 12-29-14, 09:10 AM
neptune777
neptune777's Avatar
Default windshield wiper fluid frozen
when temperature is lower than 15 degrees windshield wiper fluid freezes in supply line or squirter. Is this because of the cover at top of inside of the hood? Does that cover prevent engine heat keeping the system operable at lower temperatures. We need this system operable in the mountains of CO where ice melt is spread on the roads.
Old 12-29-14, 09:30 AM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
You should use a different fluid. Something like these
http://www.rainx.com/product/windshi...d/#.VKGPkV4ALA
http://www.peakauto.com/products/win...with-rain-off/
Could also install a fluid heater
Amazon.com: AlphaTherm AT-38OD Windshield Washer Fluid Heater: Automotive Amazon.com: AlphaTherm AT-38OD Windshield Washer Fluid Heater: Automotive
Old 12-29-14, 08:29 PM
NTH
NTH's Avatar
You should winterize your washer fluid by adding a washer antifreeze or pump out the old fluid and pour in the products mentioned above. They should be good for temps to -20f
Old 12-31-14, 08:07 PM
YoshiMan
YoshiMan's Avatar
You probably have the watered down summertime formula in there still.
Old 01-01-15, 04:53 PM
IanB2
IanB2's Avatar
As others have already said, you should be running winter washer fluid in those conditions. If allowed to freeze, it could split lines, tanks, etc and cause damages.
TheBigGuy
17
02-21-09 12:26 AM
schan1w
Maintenance
01-05-09 04:10 PM
JZA80MHU38
11-07-05 06:50 PM
Quick Reply: windshield wiper fluid frozen
