Old 12-12-14, 03:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Rear Shock Replacement With Toyota 4Runner OEM Replacements
Old 03-25-14, 11:27 AM
  #31
RCsGX
RCsGX's Avatar
Originally Posted by bhesse
Amazon.com: KYB 344410 Excel-G OE Replacement Shock: Automotive
KYB 344410 Excel-G OE Replacement Shock rear
Why buy that when a OEM shock is cheaper?
Old 03-25-14, 11:55 AM
  #32
2OnyxLexus
2OnyxLexus's Avatar
Originally Posted by sprocket
Exactly which shocks did you order? Did you have the same issue another person had with the lower washer?
I bought oem shocks and struts in a bundle. Yes I had the same issue with the bottom washer. Instead of a tapered punchi used a step drill bit. Worked like a charm.
Old 03-25-14, 12:08 PM
  #33
burny
burny's Avatar
yes sir ee
Old 03-25-14, 05:24 PM
  #34
bhesse
bhesse's Avatar
I was under the impression KYB is OEM replacement on Toyota-
Amazon.com: KYB KIT 4 FRONT & REAR shocks / struts 2003 - 09 TOYOTA 4-Runner: Automotive Amazon.com: KYB KIT 4 FRONT & REAR shocks / struts 2003 - 09 TOYOTA 4-Runner: Automotive
Old 03-25-14, 06:55 PM
  #35
RCsGX
RCsGX's Avatar
Toyota uses several manufactures for shocks. KYB could be one of them.
Old 07-15-14, 03:18 PM
  #36
thinhngo
thinhngo's Avatar
Thanks for the post guys!
Can someone please let me know if the part of this link would fit both side of my 2007 GX470? The rear passenger side start leaking now. Just wanted to double check before I place the order.
http://www.toyotapartsoverstock.com/...853080372.html
Thanks again!
Old 07-16-14, 08:54 AM
  #37
RCsGX
RCsGX's Avatar
Thanks again!
Yes that'll work.
Old 07-16-14, 04:58 PM
  #38
2OnyxLexus
2OnyxLexus's Avatar
I have notice that the rear shocks have become very soft. I did pull something kinda heavy a few weeks afterwards. Don't know if I over stressed the shocks or the air bags. I might swap out the oem fir the bilsteins. Any ideas.
Old 07-22-14, 11:54 AM
  #39
470SNC
470SNC's Avatar
you can use any aftermarket FJ/4runner rear shock, I plan on installing my Icon VS2.0s, thanks for the write up, seems straight forward and at most a 30 minute job a side
Old 07-23-14, 05:07 PM
  #40
ST2Alpha
ST2Alpha's Avatar
Awesome information! Cross over part's information is always a huge help to the pocket book.
Alpha
Old 07-24-14, 09:47 AM
  #41
470SNC
470SNC's Avatar
oh one thing to keep in mind 07-09 fj compatible rear shocks work, the 2010 and up FJs had a different size mounting hole at the bottom of the shocks
Old 07-25-14, 07:37 PM
  #42
thinhngo
thinhngo's Avatar
I can't get the top bolt of the shock off? My shock keep spinning... Any idea?
Old 07-25-14, 09:54 PM
  #43
RCsGX
RCsGX's Avatar
Cut the top off or do what the member did on page 2 / post 26;
Originally Posted by bigguppy
My shock were turning so I was unable to take off the top nut. I went ahead and tide it in place. It would of been easier to cut it off but it was around 11 PM.
Old 07-26-14, 02:06 PM
  #44
thinhngo
thinhngo's Avatar
Thank you RCsGX! I cut them with Rep. Saw... I am ready for the long road trip w/ the new shock . Thanks again!
Old 07-27-14, 06:16 PM
  #45
470SNC
470SNC's Avatar
All you gotta do for the rear shocks is get a set of locking pliers and clamp on the top of the rear shock below the actual frame mount to keep the shock from rotating when loosening the top bolts, not need to cut it off.
Quick Reply: Rear Shock Replacement With Toyota 4Runner OEM Replacements
