90k Service and fender flair seperation
2006 with 87,0xx on it so I am rolling up to the 90k service. Since I don't have the time or all the tools to do it myself, I was wondering what some of you had run into cost wise at the dealership. I am trying to prepare myself for a possible $1,000+ service.
Also, like everyone, there has been bitterly cold weather and moisture. I noticed on the rear passenger fender flair it is starting to separate from the body near the door panel. About a quarter of an inch. You can see the tape being pulled between the body and fender flair piece. I do not see any of the screws or snaps being pulled. I assume water/snow somehow worked into it and the cold expansion started to separate it. Any thoughts or let the body shop tackle it? Will try to post photos later.
Thanks
Thanks
I recently had someone back into my driver's side door and scuff the paint on that rubberized panel. Because my GX is black, refinishing that lower panel with a panel-to-panel match was an easy job for the shop. I watched the technician remove the panel and also watched him re-install it after it was re-finished. Both the removal and the re-installation took less than 5 minutes. It may be the case, however, that the shop has to order the clips (at a ridiculous price from Lexus). The ones needed for my door panel are a Lexus-specific clip, and the more generic clips that the shop had on hand would not work.
shenry500
10-02-12 10:00 PM
