Having a Problem with ProXenon HID Lights
Old 01-25-03, 10:27 PM
looknow12
looknow12's Avatar
Default Having a Problem with ProXenon HID Lights
I have installed them and they work!! But I cannot turn off the highbeams.
Any ideas?
looknow12 is offline
Old 01-25-03, 11:05 PM
D4SSWME
D4SSWME's Avatar
Question Which one did you get?
i purchased the 9005 kit and installer told me that it could not be installed due to wrong bulb size.
which kit did you purchase at ProXenon?
D4SSWME is offline
Old 01-25-03, 11:42 PM
looknow12
looknow12's Avatar
9005 BC3-6K Generatin III HID Conversion Kit, by Bohmen
Funny thing is the sales guy told me specifically that these were for low beams. The bulbs only fit in the high beam socket.
Now I'm left with the dilemma of trying to figure out why the high beams are stuck on. The dashboard display even indicates the highbeams are on regardless of the position of the light lever.
Old 01-25-03, 11:58 PM
D4SSWME
D4SSWME's Avatar
Unhappy Returns
I think that our lowbeams will not accept the HID kits since the bulb type is H11
I have not seen any HID Kits with this type of bulb.
Since I hardly use the highbeams, I'm hoping to exchange my 9005 for a 9006 which I can use in another car.
Shucks, I was hoping that we could change our lowbeams for a HID kit.
Let me know if you find one for our GX.
D4SSWME is offline
Old 01-26-03, 12:07 AM
looknow12
looknow12's Avatar
I just sent an email to ProXenon. Again, I was told these were for the low beams. Not a big deal at this point, I kind of want to be able to at least toggle between high and low though.
Old 01-26-03, 12:10 AM
D4SSWME
D4SSWME's Avatar
Question Figure it out?
kindly let me know when you figure out why the highbeams are always on.
if i can't return my 9005, i will just install them on the highbeams like you did.
i don't want to install them until i know that you are able to resolve the highbeam always on issue
thank you!
D4SSWME is offline
Old 01-26-03, 10:55 AM
looknow12
looknow12's Avatar
Will do. I haven't received an email yet from them. I'm gonna take another whack it this morning. I think it might a factory relay stuck on.
Old 01-26-03, 12:29 PM
looknow12
looknow12's Avatar
Confirmed the following.
If you remove the high beam headlamp fuses from the panel, the indicator in the dasboard does not light up indicating hibeams. This tells me the relay most likely doesn't trigger unless there is a load beyond it.
If I remove the lights and put the factory bulbs back in, things return to normal.
I believe the relay needs to be replaced with one with a higher amp rating. Going to look on the web to see.
Old 01-26-03, 12:30 PM
D4SSWME
D4SSWME's Avatar
Question replace fuse
the instruction manual mentions something about changing the fue to a higher amperage (it hink 20 or 30 amps)
just checking if you did this
D4SSWME is offline
Old 01-26-03, 01:26 PM
looknow12
looknow12's Avatar
Mine didn't come with any packaged instructions :-(.
Will need to go to an autoparts store to try. Still kind of strange that a fuse would cause this kind of issue (high beams being stuck on)
Old 01-26-03, 02:36 PM
D4SSWME
D4SSWME's Avatar
Default let me know if you need a copy
Hi, Looknow
let me know if you want a copy of the instruction manuals.
i think though that it may be available for download in the ProXenon website
D4SSWME is offline
Old 01-26-03, 03:00 PM
looknow12
looknow12's Avatar
Yes please :-)
I just determined that the high beam connector feeds one 12v and one ground when the high beams are on. When the high beams are off, both are 12v. Makes sense I guess they are just toggling the ground when the hi beams are turned off.
I might be missing a ground connection the instructions say to do.
Old 01-26-03, 03:15 PM
D4SSWME
D4SSWME's Avatar
Default email address or fax number
advise your email address or fax number so I can forward a copy of the instructions
D4SSWME is offline
Old 01-26-03, 03:33 PM
D4SSWME
D4SSWME's Avatar
Default send me an IM
Looknow12
send me an IM message so I can get your email address or fax number for the installation instructions
D4SSWME is offline
Old 01-26-03, 04:32 PM
looknow12
looknow12's Avatar
michelp@icode.com
Quick Reply: Having a Problem with ProXenon HID Lights
