Problems already?
Problems already?
Preface: I have searched the forum but haven't found a definitive answer...
A week ago I picked up my 05 GX with 55k. Loving it so far btw...
Earlier today I had planned to grab a quick lunch out of the office. I went out to the vehicle, started up as usual and then proceeded to try and roll down all windows. (it was ***** hot in the truck!)
To my chagrin only the drivers side would roll down from the drivers master panel. I also noticed that the steering wheel didn't return to it's normal position after inserting the key. Additionally the mirrors didn't tilt when I put it in reverse. Also, the drivers side master door lock switch now does nothing.
Upon further investigation I lost the ability to roll all windows down with the remote AND while inserting the key in the door to unlock.
Now, all of this was FULLY functional just hours before...and the truck simply was sitting in the parking lot up until this point.
This obviously is more than having to just reprogram the windows, as other elements are not functioning.
Could this be the battery? FYI, I believe it's fuse 29 that COULD cause this...it is NOT blown and is fine. Could it be a relay. Seems to be affecting too many things to be a short or and actuator...among other somewhat common failures I found while searching.
Thanks for your help!
Any extended warranties? Having that many issues all at once sounds more like a computer failure of some sort. It's certainly not common, but sounds like one for the dealer.
Sounds like an issue with the battery connection. If the vehicle looses power the windows need to be reset/reprgrammed. A search on this site will find that process for you. I would then check for corrosion or a loose connection at the battery terminals.
Could the battery be that smoked that it does't power those adequately yet it still cranks the engine over just fine?
Side note, I do believe it's the original battery. The battery life indicator on top however, does nothing. It's all black, no colors, red dots, nothing...
Wow... this is a good one!
If the clock was off and your steering wheel stopped mid way to position as well, I'd definitely take a look at the battery before thinking about relays etc. Sometimes, as strange as it seems, the simplest answer is the correct one. As mentioned before, take both terminals off and check for good connection. Take a really, really good look at where the ground cable attaches to the frame.
Do you have a load tester? If so, test the battery and the alternator. If you don't have one, I'm guessing that most stores that sell batteries will have one and may test your battery and charging system for free?
As for the windows, is there any chance you didn't get the procedure exactly right? Read the procedure in your owners manual and try again. I've seen it done improperly and not work the first time.
Failing that, perhaps Mann777 can give you some insight before you head to the dealership where you may or may not get someone that has a clue.
Let us know...
Chris
Let us know...
Chris
Good luck.
I brought it back to the BMW dealership I purchased it from first thing Monday morning. Well, here we are, Thursday, and they still have not been able to fix the issue. At this point they've replaced the window control module. That solved nothing. Then they replaced a computer or brain unit in there, again, nothing. They're giving up. They're actually bringing it to the Lexus dealer down the way.
Hopefully Lexus is able to tackle this one.
I must say, Minnetonka BMW has treated me very well. They are stand-up folks!
More to come...
**Update**
More to come...
More to come...
