Outside rubber window seal replacement...
As you can see from the pictures, the rubber window seal on the outside is falling apart. This is purely cosmetic at this point. This is the only issue with my GX, other than that, the truck is solid.
I pulled the rubber back so you could see it in the pictures, but usually the rubber sits in the channels.
Can I buy replacement seals or can a window/auto glass shop replace it? I don't want a half/*** job and I would rather provide seals that I know fit than them us a "generic" seal that works on "all" vehicles and have look cheap.
Thoughts?
Thoughts?
Same problem here, hit a dead end pretty quickly:
http://lexus.sewellparts.com/oem-cat...X470-2007.html
I'd send them a message but they weren't responsive last time, even though I just bought a key from them for a couple hundred.
The chrome liner includes the rubber strip. $90 part from the dealer I believe. I'll be purchasing this for my rear passenger window soon. I think its held in place by a hex bolt of some sort.
