GX460 wheels on a GX470
Just bought a 2005 GX470 with stock 17" wheels. I would like to switch to a set of 18" chrome GX460 wheels. Will my existing tire pressure sensors(tps) work on the 18" GX460 wheels? What size tire should I use on the 18" wheels? Any input is appreciated.
I'm about 99% sure that your stock sensors will work with the newer 18" GX wheels. I just bought aftermarket TPMS sensors for my stock GX wheels and the write up from the seller (eBay) said that the sensors I bought were compatible with 03-12 GX's as well as 03-12 4Runners, and up to 06 Tundras and 07 Sequoias as well as many other makes and models.
Worst case scenario, you could buy after market ones like I did. They only ran me $36 a piece (that was less than $200 for a set of 5 incl. shipping).
Hope this helps.
Hope this helps.
Yes, existing TPMS will work perfectly fine on your 18" wheels.
I have set of 18" wheels (high-shine silver) with tires from 2013 GX460, brand new. Interested?
koko777 (06-09-19)
Like others have said, your stock TPMS will swap over without any problems. What size tire is up to you. Im running a tire just shy of 33" in diameter on aftermarket 18" wheels. Stock tire size is a little over 31".
You can use this tool to compare tire sizes: http://www.1010tires.com/tiresizecalculator.asp
I bought new sensors from TireRack, but the ones from the OE wheels would have worked fine too.
https://www.clublexus.com/forums/gx-...ew-wheels.html
Bruin1md
GX - 2nd Gen (2010-2023)
07-02-16 02:49 PM
