Help replacing nut and ? on gear oil
Old 06-19-11, 07:27 AM
kphu
kphu's Avatar
Question Help replacing nut and ? on gear oil
Hey Guys,
During the 90k service that I did last weekend with my brother, I dropped a nut somewhere, couldn't find it and had to borrow one from the valve cover gasket. I went to the Toyo dealership and they couldn't help i.e. they don't stock it and don't know the exact nut to order. Does anyone know how I can get a nut to replace it?
During the TB replacement, I was planning to do the gear oil change but the toyo dealership doesn't sell the GL-5 oil. I went to the parts store and bought some universal oil that meets spec for GL-3, GL-4 and Gl-5 gear oil but I'm hesitant to use it because the oem book says you should use only toyo GL-5 oil as incompatible oils may cause your drive-shaft to seize up over time. Any recommendations?
Thanks,
Ken
Old 06-19-11, 07:55 AM
mann777
mann777's Avatar
Wink
I think this may help, just run thru the document and it has the toyota part number. Hope it helps cheers
Old 06-19-11, 07:00 PM
kphu
kphu's Avatar
Thanks mann777, I couldn't ask for more then this!
Anyone know how I might be able to identify the part number for the valve cover nut? I want to replace the nut ASAP before it causes any potential leaking due to vibration.
Thanks!
Ken
Old 06-19-11, 07:30 PM
kphu
kphu's Avatar
I think i found the part...9415080641
Will need to verify tomorrow.
Old 06-20-11, 06:58 AM
kphu
kphu's Avatar
back to the drawing board...too small.
The one for the valve cover is 12mm...
If anyone can help here's a picture of what I need. I'm sure its a common toyo nut.
Old 06-20-11, 05:24 PM
Turbinator
Turbinator's Avatar
I once asked the Lexus guys for a bolt to help hold on the skid plate. They told me to go to the hardware store since they don't stock those in-house. I took their advice, found a nice stainless looking bolt of the same pitch and size, and installed it. All's well. I would suggest you just get a suitable replacement from Home Depot.
Turby
Old 06-21-11, 06:09 AM
97JZA80
97JZA80's Avatar
You can definetly get something from the hardware store in a pinch and you'll be fine. That being said, I order nuts and bolts all the time from the dealer, for some projects it just makes more sense than spending time in the hardware isle. The parts people definitley dont want to look for it though, but if you go with a part number they are happy to just order it.
Not sure what you need, but find the part number here and order. And yes it won't be in stock most of the time but normally they have it very quick.
http://www.*******.com/parts/p_U_200...AZKA_1104.html
Not sure why those ****** are appearing, hit the url then replace them with T O Y O D I Y and it will work. Wonder what thats about CL?
Old 06-21-11, 07:20 AM
kphu
kphu's Avatar
Turby
yeah, I was planning to do this as my last resort. I'm surprised that if the dealership values you as a customer that they would get a tech from the shop to get one for you. I'm sure they lose or strip nuts/bolts often enough where they would need to replace it. If so wouldn't they have a bin of some sort with nuts hanging around in that you might be able to dig through?
This is neat..thanks for the link.
I just used http://lexus.sewellparts.com/accesso...X470-2003.html as they have diagrams online to help identify the exact part your looking for.
The diagram didn't show the part I need but i did find 3 other part numbers that might work.
90179-08153
90179-06193
90179-06129
I called local toyo dlrship and its on order. Hopefully one of them is the right one. If not its only $3.50 and I'll make my way to HD to find a nut.
Old 06-21-11, 07:36 PM
kphu
kphu's Avatar
2 strikes and a home run. Got the right nut and locked it on...back to normal.
Old 06-22-11, 05:48 AM
97JZA80
97JZA80's Avatar
Congrats...now if your like me, that lost nut will appear now that you don't need it....
Old 06-22-11, 01:27 PM
kphu
kphu's Avatar
that would be typical of murphy's law but when it was lost I looked for it high and low...no where to be found. The maintenance was also done at a friend's house 87 miles away so chances are I won't see it again unless it was hiding in the frame somewhere and rolls out onto my driveway...then I would really go nuts!!!
By the way nice Supra!!! I owned 3 supra's ('85, '84, '88) before the family came...would like to get a garage queen someday. I'm still in love with the '90 - '92 models and would get one if I can find a clean unmodified one with low mileage.
Old 06-23-11, 05:06 AM
97JZA80
97JZA80's Avatar
Thanks, yeah luckily my family is just now coming, so since its paid for it doesnt bother anyone.
My neighbor had an 85 growing up, I still think those are awesome looking.
clean and unmodified is becoming a bit of a unicorn....and starting to pull major coin. They are out there tho...
Old 06-23-11, 09:28 AM
Turbinator
Turbinator's Avatar
Great, so it was the dealership that pulled through for you?
Turby
Old 06-25-11, 06:10 PM
kphu
kphu's Avatar
Turby
not really, I used sewell lexus online parts to look at the diagrams for nuts that may fit with part numbers. I then used the part numbers to call local Toyo dealer to have them verify pricing (since no shipping costs to me) and had them order it.
anguyen3
05-09-19 05:38 PM
skyline03
RX - 3rd Gen (2010-2015)
02-05-18 12:44 AM
bigguppy
01-15-09 09:16 PM
PandaSC300
Maintenance
12
10-24-05 11:59 AM
lilnard85
Performance & Maintenance
05-30-03 02:14 PM
Quick Reply: Help replacing nut and ? on gear oil
