GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Does your crossbar have any play?
Old 09-16-15, 09:54 PM
SC3coupe
SC3coupe's Avatar
Default Does your crossbar have any play?
Can you go to your car and check if both cross bar is stiff with no movement ?
On my rear bar both sides it can move a little bit, while the 2 **** holder is tight on the side rails
I found 2 screws under each but I wanted to know if the play is there to allow for expansion
I found it odd that both sides have about the same play. But if only one side was loose I probably won't feel any play
See the picture it is the 2 torx threaded from the bottom up
Old 09-16-15, 10:31 PM
SC3coupe
SC3coupe's Avatar
Well I took a torx bit to it and sure enough the rear bar bolts were completely loose.
I made a tool by using a tiny vise grip to hold a t25 bit
I layed a towel in the work area as to not scratch the paint since the space is tight.
I just snugged the bolt and the play in the bar is gone.
I read somewhere you don't want to really crank it down and I think they are just set screws
I did both bars 8 bolt total to make sure they are at least a little past hand tight
So if your bar rattles or is loose this is at least a temporary fix and something to check regularly
Old 09-17-15, 11:39 AM
NTH
NTH's Avatar
Just checked. Rock solid
dminah21
09-01-18 08:04 AM
Champstar
Suspension and Brakes
06-19-15 07:18 AM
kanklez
11-24-10 10:00 PM
tmaung
07-16-09 02:16 PM
Quick Reply: Does your crossbar have any play?
