Need Advice With Towing Equip
#31
Originally Posted by CVsGX470
sayadil...damn i wish i would have taken a picture, but my hitch (which was on the car when I got if from the dealer looks like as Silverlady explained. There is no notch cut out of the bumper but instead it looks like the picture on the right. It is from Lexus so maybe that is how they are doing now???
CV
CV
#32
Originally Posted by sayadil
hey thanks for the info.. compared to Malhocks pic.. how much does ur hitch stick out.. same more or less.. thanks
CV
#33
Originally Posted by malhokc
Attached is another view of the aftermarket hitch.
thats a good price.. also i noticed your hitch has a lexus symbol on it.. where did you get that from..? pls advice. thnx in advance.
#34
mulhock.. can u please resend me the link to your hitch.. also does that price ( i believe was $168) include everything (except instalation offcourse) wiring and all.
#35
CV
#36
Shipping was 99cents with total price of approx 168. I had Uhaul put it on for $40 for approx 20 min of labor. Other places were more expensive ($80). If you can unscrew the bolts from the frame youself, it's a piece of cake on install it. You may need someone to hold the hitch, however (approx 35 lbs). The lexus cap is from the dealer but you can get for approx $10-15 from ebay and other sources.
Hope that helps,
#37
This is the link http://www.etrailer.com/Merchant2/m...Category_Code=H
Hope that helps,
Hope that helps,
#38
Sooo... Last night I installed my "Hidden Hitch" trailer hitch, purchased from JC Whitney for $179.99, with free shipping. To their credit, it arrived three days after I ordered it.
Initial impressions: Should work fine for the light duty towing (landscaping trailer with 2K max load capacity) that I plan to do with it... As others have noted, it does not have the four bolts in the center, just a total of 8 bolts around the sides... 6 large bolts and two smallers ones... Looks OK, similar to factory, but not identical. You lose the use of the factory tow hook with this unit (factory unit has it built in) but I may be able to retrofit it somehow, ran out of time (see note about darkness below)...
Installation: PITA! Had to remove a number of chunks at first (tow hook, two fascia chunks that the rear fascia attaches to, the electrical connector had to be unbolted and moved to the side for installation purposes). Instructions were not the best, but I eventually made heads and tails of it... (Most of the actual installation of the bar itself was straightforward (see "Nut on a stick below), it was the ancillary stuff that was confusing...) Of course, it didn't help that I was doing this in my driveway, and since it took longer than expected, it was dark by the time I finished... daylight and a lift would have made it much easier... Installation on the driver side was easy (air tools) but passenger side, the exhaust was in the way, so it was hard to work around it... Unit came with "nuts on a stick" that you had to feed through a slot in the bumper, and align with a metal chunk that you were supposed to tape to the nut on a stick, but then it wouldn't fit through the slot... ended up dropping the metal chunk through the slot by itself, positioning it with a tool, and then being very careful not to lose it as I held the nut on a stick in position, and tried to screw the bolt into it... My guess is this was all done to avoid removing the rear fascia... but it was really annoying... Speaking of the rear fascia, since one had to remove the metal chunks that it bolted to, after all was said and done, you had to re-attach the fascia in someway so the wind wouldn't catch it... they provided some zip ties and you were supposed to make some sort of elaborate lasso system... I just used some longer zip ties I had lying around and zip tied the fascia to the tube... looks like it should work fine...
Overall impression: A reasonable deal if you are handy with tools and don't expect to tow excessive loads... I will probably only use my vehicle to tow a trailer maybe 6 times a year... If you routinely tow heavy loads, I think I'd go with the factory unit...
#39
Be careful with ordering hitch from Lexus dealer. I ordered one from my Lexus dealer when buying and assumed they would put on Lexus brand hitch. Surprised when my vehicle arrived with a 3rd party hitch!
#40
#41
Originally Posted by BobsGX
Wow, sounds like you had a field day installing the aftermarket hitch. With the official Lexus hitch, nothing involved even touching the rear fascia and certainly no zip ties were involved in the process. And the factory installed tow pin gets installed in the same place as it came from the factory. I did mine while laying on my back in the garage. Easy installation, but I guess it should be.
#43
Thanks! I remember reading a previous post where you mentioned that... I'm not too concerned about it, as I don't plan on pulling anything close to the 6500 LB capacity of the vehicle... My old S-10 pickup truck hitch was mounted the same way and never had an issue (towing the same type of things I'm towing now); however, I'll keep your suggestion in mind if I win the lottery and end up buying a huge boat or something!
#44
After reading this entire Thread, I think the guy who did the Hidden Hitch had the best strategy. I'm gonna take the $$$ I save by using the Hidden Hitch and spend it on something else for my GX. To each their own, but for me it's the Hidden Hitch for sure. I love this Forum.
