F Sport 18" 2014 GX460 Michellin 265/60/18 + Muffler Damper
Finally got this done.
Upcoming project
Sound deadening this Spring 2017,
Llamar Protective Clear Film for Sound barrier Summer 2017
Upcoming project
New Wheel 18 F Sport, Transmission Oil Change, Muffler Damper
Install New Wheel F Sport 18 inch
New Tire Michellin Smooth Quite Soft Ride Replacing Bridgestore D/H Dueller same Size 265/60/18
3 Muffler Damper ( I can't stand muffler drone at speed over 65mph)
Transmission Oil Change with Amsoil Signature Series...Smooth driving No more Jerking after slowing down and sudden acceleration (31K miles) 51/2 quart
Replace Transmission Filter
Update: Muffler Damper Welded
The following 2 users liked this post by abudiman:
ltsr (09-23-19),
SigEpGX460 (07-02-18)
Yes Amsoil solve this and its only take 5 1/2 quart, some guys drain and refill drive around 5 minutes and drain refill again, but mine just once with Amzoil and Jerking goes away . I replaced my old GX470 with this Amsoil too and the results is speechless.
Update:
The muffler mount doesn't do a good job I feel the mount is vibrating so I'm going to weld it by muffler guy
Update:
Thanks for the info. Did the position of dampers get rid of the droning? Was there one that was particular helpful? I had seen a post somewhere that suggested placing at the inlet of the muffler. I'm seeing the droning at around 2000 RPM, at any of the gears. Thanks for any help
Do you have any links to the dampers you used? Are you happy with the end result?
Hello Sig
I picked the location where debris like plastic bags may not get caught by this damper. No science behind my placement but just imagination how the plastic bags might fly underneath the car.
cxc511
01-11-14 10:07 AM
