starting
Old 04-04-16, 08:32 AM
abej
abej's Avatar
Default starting
is it normal for the engine to start at 2000rpm and slowly drop?
abej is offline
Old 04-04-16, 08:53 AM
Booyah
Booyah's Avatar
Yes for a few seconds especially when cold
Booyah is offline
Old 04-04-16, 09:05 AM
T4Fun
T4Fun's Avatar
all toyotas do that. its usually high and goes down in 1-2 minutes
T4Fun is offline
Old 04-04-16, 09:34 AM
Kitana
Kitana's Avatar
Funny you mentioned that. Mine gave me a jump first time I started it and I noted to my sales rep it started rather high. I had not driven a V8 in a long time. I love it! Wakes me up in the morning.
Kitana is offline
Old 04-04-16, 01:13 PM
bd5400
bd5400's Avatar
This is not limited to Toyota made vehicles. Every vehicle I've owned does it, especially when it's cold outside and it has been sitting awhile. I would assume this is the case for most, if not all, modern gas vehicles.
bd5400 is offline
Old 04-04-16, 05:50 PM
coolsaber
coolsaber's Avatar
As long as your not idling at 2000 RPM your golden. I have seen 1600 RPM startups without knowing temp on the GX460. Check youtube for some startup videos
coolsaber is offline
Old 04-04-16, 05:54 PM
angelslex
angelslex's Avatar
Yes is normal. Cold or hot weather for the first time. Once the engine is hot. It will start up normally.
angelslex is offline
Old 04-07-16, 07:25 AM
abej
abej's Avatar
thanks for all of the replies. i feel a lot better.
abej is offline
Old 04-08-16, 03:37 AM
jjscsix
jjscsix's Avatar
I've owned a lot of vehicles including other Lexus and this is a first for me. It goes against everything I know to have it immediately rev that high before the oil is fully circulating through the engine. I'm sure that is nothing to worry about, but it seems odd to me.
jjscsix is offline
Old 04-08-16, 07:38 AM
bd5400
bd5400's Avatar
Indeed it is nothing to worry about. People in northern states are likely more used to this as it happens much more often in cold weather. As stated, this is not limited to Toyota/Lexus vehicles.
bd5400 is offline
Old 04-08-16, 12:41 PM
JT4
JT4's Avatar
Same here, my vehicles will rev slightly higher when its cold outside and sitting overnight.
JT4 is offline
swaangin
02-26-20 08:03 AM
peterls
04-19-14 12:36 PM
panda08
01-24-13 11:25 AM
runningox
01-12-09 03:40 PM
ekrebs
Performance & Maintenance
12-30-08 07:44 AM
Quick Reply: starting
