Can a 2012 gx460 brainbox work in a 2010 gx460 model?
Old 10-09-13, 10:35 PM
olddog
olddog's Avatar
Default Can a 2012 gx460 brainbox work in a 2010 gx460 model?
Hi guys,
first time here.long time member though in the GS section.
My brother got a salvage 2010 GX460 that apparently needs a new brainbox. He has located one from an accident car at a local part yard. but he does not want to buy it unless he knows it can be reprogrammed to his car. Does anyone know if this is possible? What does it entail? Does anything else need to be reprogrammed if the new brainbox works?
Thanks
olddog
olddog is offline
Old 10-10-13, 04:00 AM
Koz
Koz's Avatar
Brainbox? Just check the part numbers.
Koz
Koz is offline
Old 10-10-13, 06:47 AM
T4Fun
T4Fun's Avatar
its halloween time
T4Fun is offline
Old 10-10-13, 06:58 AM
Quadro
Quadro's Avatar
Assuming you mean ECU/ECM (Engine Control Unit/Module) then yes, I believe it can be done otherwise what would you do if ECU module fails? Now it might be more involving than just ECU since you also have engine immobilizer.
Quadro is offline
Old 10-10-13, 09:25 AM
olddog
olddog's Avatar
yea i believe the ECU is what i refer to as the brainbox. i thought brainbox was a generic term in car lingo.
anyways, will it work?
olddog is offline
Old 10-10-13, 10:31 AM
Craig B
Craig B's Avatar
Call a Lexus dealer and ask for the shop foreman. Give him the part numbers to make sure it's going to work. I don't think he will be able to return the part if it doesn't work on his vehicle...
Craig B is offline
Old 10-10-13, 11:28 AM
Koz
Koz's Avatar
Not sure if the added (in 2011) brake override system would make a difference in the ECU!
Koz
Koz is offline
lexdud
Performance & Maintenance
18
08-20-23 10:15 PM
soarin87
12-17-12 09:07 PM
nivek5sfe
SC- 1st Gen (1992-2000)
07-06-10 04:38 PM
chrisman
Chicago Lexus Club
04-03-06 09:09 PM
SC400james
05-01-01 12:09 AM
Quick Reply: Can a 2012 gx460 brainbox work in a 2010 gx460 model?
