View Poll Results: Do you see rust under your GX 460?
Yes
50.31%
No
49.69%
Voters: 159. You may not vote on this poll
Rust
Old 05-14-14, 09:36 AM
  #61
Max707
Max707's Avatar
Originally Posted by Quadro
My GX is 1.5 years old and went through two Ontario winters so I also think it's not too bad but I decided to be a little bit on a proactive side and spray some low hanging fruits (keep in mind the pictures is after I sprayed the things). But I was mostly dying to crawl under the truck to learn more about it. Do you know where your fuel pump control module is located? :-)
My issue with fluid film is most of it will get washed away the first time I go to undercarriage car wash (which I do every week) so I decided to apply something more permanent. And I still need to check what's going on up front though rear is what usually receives the most beating.
With my past 3 LX's, every spring and fall I slide under the beast with a can of rustoliuem hammer coat and touch up the underside. By doing this even when I lived in the rust belt I never had any rust issues. The beast has a shiny new looking black bottom . I think of it the same as waxing the top side. Take care of your ride and it will take care of you. My current LX has lived its life in Nevada so it never had exposure to salt or much moisture. I still used rustoliuem hammer on it figure extra layers of protection can't be a bad thing. Plus these rigs are built to last 500k plus mile so why let rust shorten its life?
Old 05-14-14, 09:59 AM
  #62
Quadro
Quadro's Avatar
I used Eastwood Rubberized Rust Encapsulator. I found the spray works fine for big parts and is very easy/low effort to apply but for some other parts I've ordered the stuff which can be brushed on so I have more precision and going to test it once it arrives.
Old 05-15-14, 08:58 PM
  #63
T4Fun
T4Fun's Avatar
there are too many bolts crevices joints to be painted accurately, so i just douse the whole thing with fluid film.
i dont do the underbody wash, because water will get into places where it shouldnt go and cause more rust imho. Fluid film does a great job of protecting the metal with a grease layer.
Old 05-16-14, 06:41 AM
  #64
Max707
Max707's Avatar
The factory coating and paint will keep the rust away. Plus clean is good, no salt on surfaces is a good thing. Problem with most rusting is bare metal exposed to salt and moisture in a warm garage i.e. Rust belt vehicles in the winter. Anything that keeps moisture, salt away from the bare metal works.
Old 05-16-14, 11:13 AM
  #65
T4Fun
T4Fun's Avatar
here is the stuff i spray under the gx.
http://www.fluid-film.com/applications/automotive/
Old 05-16-14, 11:14 AM
  #66
dstock
dstock's Avatar
3 years old here and I've got rust also!
Old 05-16-14, 11:22 AM
  #67
Quadro
Quadro's Avatar
The only people who don't are the ones not living in the rust belt.
Old 05-19-14, 07:53 AM
  #68
dstock
dstock's Avatar
So you consider Texas in the rust belt?
Old 05-19-14, 10:32 AM
  #69
Quadro
Quadro's Avatar
Didn't pay attention you're in TX! Yes I would not expect to see any significant rust for a vehicle in TX. Do you have some pictures of the underside?
Old 07-28-14, 06:58 PM
  #70
T4Fun
T4Fun's Avatar
round 2.
sprayed it all underneath and doused the frame and axles while its still new with fluid film. very messy. went thru 10+ spray cans
http://www.amazon.com/Fluid-Film-11-...owViewpoints=1
Old 07-29-14, 10:59 AM
  #71
Max707
Max707's Avatar
Originally Posted by T4Fun
round 2.
Can't do much more then that. Maybe move to Texas,AZ,NV.
Old 07-29-14, 01:33 PM
  #72
Lolrax
Lolrax's Avatar
round 2.
You should consider a full undercoat treatment like the ones we get here in Canada. I wish the person who owned mine did this when it was new before exposing it to so much road salt. The car smells for a bit, but they are super effective and the treatment is once for a lifetime.
Old 08-14-14, 10:04 AM
  #73
T4Fun
T4Fun's Avatar
heres a video of fluid film.
i highly encourage all gx owners to do this....
Old 09-09-14, 06:50 PM
  #74
Greg42
Greg42's Avatar
Default rust
my gx 460 2011 has only 39000 k rust under car dealer is not responsible ????
Old 09-10-14, 06:08 AM
  #75
Eppieguy
Eppieguy's Avatar
No, Rust through would be, but not surface rust.
Quick Reply: Rust
