My Ship Has Come In
Old 05-02-11, 11:59 AM
  #31
Koz
Koz's Avatar
Originally Posted by JDUBYA
So someone has replaced these running board lights with LED's and can verify that they dont flicker? Also I would like to know the outcome of KOZ's 360 degree led's as opposed to the downfiring ones for the running boards. Are these hard to install?
I'm using the down firing bulbs (just look better) and they do not flicker. Just reach for the back of the fixture and 1/4 turn the connector to remove the fixture. There is no need to remove the clear lens (2 screws each).
Koz
Koz is offline
Old 05-07-11, 11:08 AM
  #32
JDUBYA
JDUBYA's Avatar
Default Follow up to LED Installation (KOZ)
Originally Posted by Koz
I would not bother with the turn signals (I’m not going to change them) because you would also have to install a resistor to slow the blinking. LEDs draw so little amps the blinking will be too fast without a resistor. Also the turn signals bulbs are amber and you will not see that much of a difference.
I will be finishing the exterior bulb replacements and I will take pics of all the replacements (including the domes and running board lights) and post them Sunday. I will also replace the high beams/DRL (9005) with 100w bulbs (with HD wiring for the added wattage).
These are the dome bulbs (6 needed).
http://www.v-leds.com/Exterior-LED/C...57621-1-2.html
These are the running board bulbs (4 needed)
http://www.v-leds.com/Interior-LED/D...61053-1-2.html
These are the high beam/DRL and HD wiring harness (1 pair)
http://www.buyheadlightbulbs.com/MTE...s-p/mt-450.htm
These are the fog light bulbs (1 pair)
http://www.v-leds.com/Exterior-LED/D...24328-1-2.html
Koz
KOZ, I ordered these for the running boards. Are these the 360 degree that you used?
http://www.v-leds.com/Shop/Control/f...04828/vpcsid/0
http://www.v-leds.com/Interior-LED/G...White-LED/2-V-
LEDS-5K-WHITE-194-p8804828-1-2.html
Are these the 360 degree bulbs that you used? Also how difficult is it to replace the interior lights and the fog lights? I would also like to replace the highbeams, but I do not want to stick blue bulbs in there since the new GX does not have these covered with a lense. Are there any that can be purchased that do not have a blue tint to them?
JDUBYA is offline
Old 05-10-11, 06:44 AM
  #33
Koz
Koz's Avatar
Those are not the (360) ones I used. The first link I posed is the 360's I used (which are different LEDs and brighter). I used a credit card and a small flat tip screwdriver (together) to remove the dome lenses. The credit card was used to protect when prying with the screwdriver. If you look closely at the lenses you will see little tabs on the edge of the lenses. That is where you need to pry. The fogs are a matter of just reaching behind the fixture and a 1/4 turn counter-clockwise (to take out). The DRL/high beam bulbs are not blue when lit; the high beam matches the OEM HIDs perfectly.
Koz
Koz is offline
tfeni52355
04-11-12 12:38 PM
Koz
09-17-11 08:22 PM
JFNash
11-20-10 04:33 PM
anson89
IS F (2008-2014)
04-01-09 01:17 PM
Quick Reply: My Ship Has Come In
