Please help. Car won't run. P0118, P2111, P2119
Hi guys. I mentioned earlier that a rat got at some wires in my truck. I took few things apart and the only visible issue with wires I could find , besides my hid set up, was an engine coolant temperature sensor which threw P0118 code. Can someone tell me if this or those other codes p2111, 2119 will prevent the car from running? It starts? And then after a second or two dies. I'm wondering if prolonged short of the buttery could have caused a burn to some fuses associated with the throttle body control system? I looked at fuse box and can't figure out what solunoid/fuses are associated with the throttle system.
Thanks
Thanks
P2111 and P2119 are both related to the throttle actuator. They both generally say "stuck open", so the ECU is shutting off the engine as a safety precaution (so you don't put it in gear and accelerate out of control).
The throttle body is a the top-front of the engine.
http://www.lexussouthatlantaparts.co...rimLevel=19100
Chip H.
Chip H.
So based on that there was a damage done by a rodent to the point where the car won't run I made an insurance claim today.... Will post the outcome layer.
Thank you all for all your input
Thats so Sad.I hope it all works out well. And you are a back to Soon. Sanitize your car as well once you get it back and change your CABIN AIR FILTER as well. I had rodent poop allover my 4runner's carpet once. And i couldn't figure out how it got in it..
GOOD LUCK
GOOD LUCK
LSPiNoY
10-14-04 12:00 PM
TRULUX
09-01-04 08:53 PM
