Refreshing the Entire Front Suspension.
New 04 GX. It needs a new suspension. I will be keeping it a while. So rather then go with just what is worn I was thinking of replacing the vast majority of what I know wears out on most cars at this age. I don't have a service manual and I need to get one. But I want to order the parts. Can you help me get a complete list?
- KYB Strut Mounts SM5724 Two 25.94 Each
- Upper and Lower Control arms. Left and right. Amazon has Detroit Axle ones with Ball Joint and all bushings. Two Uppers are 114.20 set, Lowers are 215.30 set
- Then the Shocks and Springs of my choice front and rear.
- Air bag delete kit in the rear.
I know I did not include the Inner or Outer Tie Rods. I am ok inspecting those myself. I can replace them later and realign that part myself if needed with out going back to the alignment shop. The rest needs caster and camber done so I can;t do that part.
Is that all of it?
Is that all of it?
Lexicon1
05-23-19 06:23 PM
alanchad
08-12-14 02:22 PM
varcity64
Suspension and Brakes
09-13-06 12:13 PM
