100k miles service
100k miles service
Greetings,
I am planning to replace timing belt and water pump on my GX470 2007 with 97,000 miles on it. Any suggestions / recommendation what else should be done?
Thank you.
Thank you.
thermostat, transmission flush, coolant flush, front and rear diff/transfer case fluid change, spark plugs, oil change if not done at normal intervals, grease zerks on driveshaft
I opted for the pan method when I had some service done around 127k miles. And will probably get it done again somewhere around 155k miles, giving me a progressive fluid change.
Chip H.
It'd have to be a really good indy mechanic -- the transmission is very sensitive to quantity and temperature of the Toyota WS (world standard) transmission fluid. You can't just throw some in there.
Chip H.
Chip H.
