GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
03 Lexus GX 470 Radiator Replace
Old 04-30-14, 09:14 AM
Romulus1
Romulus1's Avatar
Default 03 Lexus GX 470 Radiator Replace
Does anyone have a DIY or Repair PDF on replacing the radiator ?
Thanks in advance for the info.
Old 05-01-14, 09:50 PM
MichaelD86
MichaelD86's Avatar
Im doing mine on saturday. I will post some pics and let you know how it was. Shouldnt be too bad, just have to move allot to get to the four bolts that hold it in the car.
Old 05-05-14, 02:13 PM
Romulus1
Romulus1's Avatar
I would appreciate it.
Thanks
Old 05-05-14, 03:36 PM
RCsGX
RCsGX's Avatar
See attached PDF....
If you're going to do it yourself I would definintly buy a remote clamp removal tool. It's hard to get to the bottom clamp even when underneath the engine bay.
Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive
Old 05-06-14, 04:02 PM
MichaelD86
MichaelD86's Avatar
Defiantly good advice. I had to use a small set of Chanel Locks, hold the clamp so it was spread out and put a zip tie on the chanel locks then when I got the clamp in position snip the zip tie.
The whole install went pretty easy with basic tools. Also make sure you have about 18" worth of extensions to get to the bottom bolts that hold the radiator. They also need to be backed up with a wrench. Overall with a coolant flush took me about two hours.
Old 05-06-14, 04:53 PM
burny
burny's Avatar
how much tranny fluid do you lose when you lift the lines off?
Old 05-06-14, 09:02 PM
MichaelD86
MichaelD86's Avatar
Almost none, It all drained back into the tranny. I would say it was maybe 2 to 3 ounces at most. If you don't need to do a flush it only takes about a gallon and a half of coolant to fill it back up.
Old 05-15-14, 12:33 PM
Romulus1
Romulus1's Avatar
That looks pretty simple. I really appreciate the diagrams for the exchange. Thanks so much.
Jacket
GX - 2nd Gen (2010-2023)
90
03-21-24 10:14 AM
Dallasguy1
130
07-25-23 05:52 AM
TDC1
19
11-12-18 10:56 AM
new2003GX
09-13-16 11:57 AM
mann777
05-11-09 09:12 AM
Quick Reply: 03 Lexus GX 470 Radiator Replace
