GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Hub bearing grease
Old 11-18-13, 08:01 PM
Phil676
Phil676's Avatar
Default Hub bearing grease
In an attempt to figure out what is causing a pulsation when breaking, I notice white grease on the back of the wheel bearing after I removed it. Some of the grease is on the abs sensor and inside the housing where the bearing is seated as well, is this normal and could it cause pulsating when braking? I always thought these bearings are sealed.
This is my second post with this pulsating issue...already went through new rotors, tires, pads, shims, and a caliper...no change.
05 gx 470 100k miles
Thanks!
aljodoro
10-19-15 10:05 AM
techrep
08-17-14 09:39 AM
Gil Smash
04-19-13 05:23 PM
Edasov91
IS - 1st Gen (2001-2005)
04-14-12 12:07 PM
lx470man
11-15-04 04:25 PM
Quick Reply: Hub bearing grease
