GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
passenger side mirror 2005 gx 470
Old 07-13-10, 09:15 PM
samdarci
samdarci's Avatar
Default passenger side mirror 2005 gx 470
anybody know if it is possible to just purchase the insides of passenger side mirror 'mirror and plastic backing' or do you have to buy the whole side mirror shell and all ? Thankyou for the help
Old 07-14-10, 09:10 AM
LZMF1
LZMF1's Avatar
try ebay i have fund countles numbers of things i needed for my '06 gx 470
Old 07-14-10, 10:48 AM
mann777
mann777's Avatar
You only need to replace the mirror ( which comes with the actuator ) They are not quite expensive, you could have it picked up from the dealer itself, eg:- Sewell.( CL members are offered a good discount package) The part number is 87908-60840 ( LHS ) & 87909-60730 ( RHS ) Just need a Phillips to do the job max 30mts , if you are good at tooling, otherwise Learner would take 1hr-30 mts. Here is the method attached. Hope it helps. cheers
File Type: pdf
Old 07-18-10, 06:17 PM
Pearlpower
Pearlpower's Avatar
Extremely easy to swap out the components on this vehicle. If you need a DIY let me know.
Old 09-03-10, 10:57 PM
nkostaki
nkostaki's Avatar
On a similar issue, might I tap into the members' experience:
The driver's side rearview mirror in my '05 GX (rather, its European LC 120 Prado reincarnation) has been physically knocked from the back fully forwards. Something must have broken completely as now the electric controls don't work and the mirror has no resistance when I manually fold and unfold it. I'm looking to buy a replacement. The mirror in my European specs car is electrically operated/heated but there are no memory position buttons.
Could someone confirm that the mirror assembly from oemlexusparts.com at http://www.partswebsite.com/oemlexus...129&type=parts is everything I'll need for a complete swap? And that it'll work in my car without the memory position switches?
Thank you very much for helping me out.
Old 08-17-15, 07:41 PM
SC3coupe
SC3coupe's Avatar
I also have a problem with the passenger mirror.
It would go up down but rather slow compare to the driver one but not left to right.
So the wiring works, is there anything else I could try before spending on a new actuator?
Old 08-18-15, 06:38 AM
chiph9
chiph9's Avatar
You can try taking it apart and cleaning & re-greasing the gears. But if you're not super mechanically adept, you might as well buy the whole part. And it might be the motor, not the gears.
Chip H.
dimpasa
09-08-23 10:39 AM
mikeivan
LX - 3rd Gen (2008-2021)
02-16-14 05:30 PM
danmm7
10-01-12 02:11 PM
GS3Tek
09-21-06 09:14 AM
BobsGX
09-14-05 04:34 PM
Quick Reply: passenger side mirror 2005 gx 470
