Side Step Lights
The 194's are everywhere. Door panel, running boards, license plate lights, front running lights, etc.
I put the leds in the license plate lamps as well (kind of a PITA to remove the entire rear door panel to get to 'em). I also did 2 panels for the center dome (not a 194-different type), and ordered 1 more for the rear. The front two are going to be a little more tricky...
Here are the ones I used for the non-rear DVD, but WITH rear audio dome:
Amazon.com: Cutequeen Trading 2PCS White 5050 48SMD 48-SMD LED Panel Dome Light Lamp + T10 BA9S Festoon Adapter (pack of 2): Automotive
When I used to have my running boards, I replaced the lights with Philips LED. I think I ordered them through HomeDepot online. Very white (no blue) and bright. Also replaced the license plate light with Philips LED.
The interior lights were all replaced with LED but I bought them from SUPERBRIGHTLEDS because Philips didn't make the right ones.
I had mixed luck with getting LED lights from Amazon.... some were too blue and some didn't last very long.
I just did the same with some 194 LED's I bought on eBay and what a difference from the OEM lights. It really does update the look and makes my first generation GX not look so old!
tomtsops
Lighting
01-01-08 08:32 PM
