GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Location Of turn signal flasher
Old 05-01-06, 03:04 PM
darrellk
darrellk's Avatar
Default Location Of turn signal flasher
Could someone tell me where the turn signal flasher is located on my 06 GX470? I looked in the big fuse box under the hood, but I didn't see any flasher. I want to replace the OEM flasher with one rated for LED's. BTW, anyone know where I can get a flasher rated for LED,s I undertand they are all electronic, no relay.
Regards
Darrell
Old 05-01-06, 04:16 PM
Capirato
Capirato's Avatar
Regards
Darrell
Hi Darrell.....
Recently, one of my front turn signal bulbs went out. I did not notice any difference in the flashing rate between one bulb flashing or two.
Perhaps, it is not necessary to change the flasher on a GX.
Come to think of it, I have the Prado Lights which have two bulbs on each side in the rear. That may be the reason why the flashing rate did not increase.
Perhaps, it is not a problem when the load increases, such as when towing a trailer. Maybe the problem arises when there is not enough load, such as when using LEDs.
~ Cap
Old 05-01-06, 05:40 PM
darrellk
darrellk's Avatar
[Cap, thats exactly the problem. The LEDs draw so little current(milliamps) that the flasher does not operate properly.
Darrell
Old 05-02-06, 06:19 AM
sayadil
sayadil's Avatar
Darrell
Guys i recently ordered PIAA LEDS 168 for the parking light and running boards..it will work there rite???
Old 05-02-06, 12:08 PM
darrellk
darrellk's Avatar
I used those on my running boards and they look great...
jjmaxx81
07-03-16 03:30 PM
Tolip
06-01-16 05:45 PM
14blk250a
12-07-14 05:50 PM
al777
10-29-11 06:55 AM
shawnlexus
SC- 1st Gen (1992-2000)
08-24-10 08:48 PM
Quick Reply: Location Of turn signal flasher
