TroubleShoot with XD HID 4300 kit
OK.. i got the kit and tried to install it last night.
Problem:
The kit does not look like the on DIY thread... i have a seperate ballast and ignitor it seems.
Regardless, i connected everything...... one thing that was unsure was the positive battery connection. The connecter was too small to fit on the + terminal (not the area where the clamp goes on the actual battery + post, BUT the there is a screw that pops up and have a big cable hooked up to it..) hope that makes sense.
I ended up just putting it on to the main clamp area (the screw that you have the take on and off if you want to take off the clamp.)
I grounded to the side of the car just like the DIY. Unscrewed existing nut and just piggyback the thing. The relay was mounted same location as the DIY.
OEM harness only to the driverside, pass side was taped up.
The ballast and ignitor was two pieces. I taped on the ignitor on to the ballast... the two wires from the BULB was going to the ballast, then main power from the relay to the same ballast.
I just dont know why it wont work?!?!?!? bad ground?? bad + connector??? am i doing something wrong?
Problem:
Cooler is not Better
Originally Posted by kormaster
Got it all figured out now. I think i like the 6k better.. looks cooler...
But, it won't throw out as many Lumens.
Being an old man, I need all the help I can get.....
~ Cap
Hahaha. yeah.. 6k looks realy after market though.... i still like the 4300 kit.. looks so oem.
Never going back to a car without xenon. My E46 M3 had the bixenon. Loved how it autoleveled... but at the end.. all same lumen output....
fell_swoop
06-20-07 10:53 PM
