Towing a GX
Check with Remco
Although the manual prohibits towing for long distances with all wheels on the ground, you should call Remco. They will tell you if they have the equipment to modify your GX for towing four-down. I modified a 4X4 Tundra for towing behind our MH with a Remco driveshaft disconnect, but that truck doesn't have full-time 4-wheel drive like the GX. I would think you can use two driveshaft disconnects to do this, or maybe do it with a lube pump -- they will tell you for sure.
http://www.remcotowing.com
One good indication that it should be possible to tow four-down is that Roadmaster makes tow brackets for the GX and the 4Runner. You should also give them a call to see how people are doing it.
http://www.roadmasterinc.com
BTW, I met a guy in a campground once who ruined the transmission in his brand new RX330, by towing it without any modifications (the RX manual also prohibits this). Lexus was kind enough to replace his transmission for him.
Pat
Pat
