headlight is tilted, please help
Old 08-19-14, 11:07 PM
CarKrayz
CarKrayz's Avatar
Default headlight is tilted, please help
I recently bought the 2007 gs350 awd.
drove it at night for the first time and realized the driver side headlight is tilted however the passenger side is fine.
The cut off should be ______/------------ however it is tilted in about a 20-30 degree angle instead of it being parallel to the ground.
Please help if you know what can be done. I will try to take pictures of it when i get the chance.
Thank you in advance.
Old 08-20-14, 06:52 AM
BinaryJay
BinaryJay's Avatar
Something is definitely not right with that because they only adjust up, down, left and right. There is no adjustment for rotation. Does the affected headlight move (self level) when you first start the car at night?
Old 08-20-14, 08:44 AM
XxGoKoUxX
XxGoKoUxX's Avatar
The headlight bulb (when replaced) wasn't aligned properly in the housing. Readjust until the light is nice and straight.
Old 08-20-14, 12:57 PM
BinaryJay
BinaryJay's Avatar
When I last replaced mine I don't remember there being anything to adjust, it just locks in place and there is no wrong way to do it?
Old 08-20-14, 01:00 PM
XxGoKoUxX
XxGoKoUxX's Avatar
There is, sometimes the bulb doesn't seat properly and you lock it anyway, usually user fault. I've done it before, even Lexus techs have done it wrong too.
Old 08-20-14, 03:30 PM
warandcar
warandcar's Avatar
wow we learn something new everyday...
Old 08-20-14, 05:19 PM
CarKrayz
CarKrayz's Avatar
great info everyone, i will check the bulbs again.
yes, when i start the car the lights does go up and down to auto level.
Old 08-20-14, 08:13 PM
CarKrayz
CarKrayz's Avatar
again thanks for the info, I had just fixed the issue.
I had to adjust the driver side more to the left and passenger side more to the right and aim it higher. It appears to be leveled once i did the changes.
I dont know if it had anything to do with it but the tire pressure was a bit off so i made all 4 tires the same 33psi
I can see the road very clear now and from the cut of when i drive next to the park cars. it does not hit the side mirrors, it is parallel to the ground by the mid way of the doors. shouldnt blind anyone on the road at all.
Cruf665
03-29-18 01:12 PM
Vasiliyd
SC- 1st Gen (1992-2000)
12
03-18-13 02:32 PM
nsxiboi
03-15-09 06:53 AM
GS3.0
12-14-05 08:38 PM
Quick Reply: headlight is tilted, please help
