How do I replace the belt tensioner assembly?
Old 06-27-14, 08:30 PM
StLB5
StLB5's Avatar
Default How do I replace the belt tensioner assembly?
I messed up. I was replacing the water pump and trying to get the tensioner pulley out of the way and I went the wrong way and snapped it off. I found the part from rock auto, but how the heck do I get to it? It looks like I have to remove the AC condenser. Does anyone have diagrams for getting to the tensioner assembly?
Old 06-30-14, 02:08 PM
StLB5
StLB5's Avatar
Can anyone help or point me in the right direction?
Old 06-30-14, 06:02 PM
ibidu1
ibidu1's Avatar
Ive done a water pump and the job was super easy. Snap a picture of the damage screw and we can help guide you easier.
Old 06-30-14, 06:16 PM
StLB5
StLB5's Avatar
I got the water pump replaced. I snapped the tensioner pulley off and need to replace the tensioner assembly
Old 06-30-14, 06:33 PM
ibidu1
ibidu1's Avatar
https://www.clublexus.com/forums/gs-...placement.html
Old 06-30-14, 06:48 PM
StLB5
StLB5's Avatar
That's all quite easy, the problem is the tensioner pulley is broken. In trying to remove the pulley, I went the wrong way with the breaker bar and broke the metal that the tensioner pulley screws in to. I need to know how to replace the tensioner pulley assembly. I believe it entails removing the aC unit.
Old 06-30-14, 07:09 PM
ibidu1
ibidu1's Avatar
If you have to take off the ac compressor and brackets it is not difficult and you do not have to release the freon in the system. Just unbolt it, and use a wire to hang the compressor so it doesnt bend and break the ac lines.
Old 06-30-14, 07:15 PM
Kuleaze
Kuleaze's Avatar
There is a bolt that goes through the tension arm and into the pulley, is the arm broken, or is the pulley itself broken?
Old 07-01-14, 09:26 AM
07LEXPL
07LEXPL's Avatar
I did the same thing this weekend, i ordered a new bolt from lexus. cost $3. not sure if you broke the tensioner itself or just the bolt that holds the pulley onto it. you won't find this reverse thread bolt on websites all they show is the tensioner as a unit. i had to call them to get the bolt.
jizz4jazz
04-12-17 10:47 AM
jsibayan
05-15-14 01:07 PM
mandyfig
12-23-13 06:31 AM
Och
22
02-02-08 11:59 AM
Quick Reply: How do I replace the belt tensioner assembly?
