DIY 2006 Lexus GS300 Alternator HELP!
Hello,
I am having trouble removing the alternator from a 2006 Lexus GS 300. I've attached some pics for the bolts I have already removed. For anyone that has done this.. What am I missing?
I also removed the battery bolt (not pictured)
Hi Guys
How long did this take you? (Changing the alternator)
My Garage said it took them 5hours just to take it out!
Also, what went wrong with your alternator? Did it smoke?
Removed all bolts mentioned but no give
Hey guys, went through the trouble of removing all mentioned bolts the 2 main ones in front, the one that connects to the battery and the 12mm bracket nut that bolts into the engine block (I believe) I tried wiggling it left and right and it still won't budge, what gives
Fixed
Changing the alternator on a 2006 Lexus GS300 RWD.
1) Remove the plastic covers from the left side, front and over the engine under the hood.
2) Disconnect the negative cable from the battery. Good time to clean the terminals of the battery also.
3) Remove the serpentine belt. Might want to replace this now also.
4) Remove the plastic cable holder from the stud sticking off the top front mounting ear.
5) Remove the main cable to the alternator using a 10mm socket and some extensions and a universal joint. Some electrical tape around the u join will keep it from flopping to much. Especially help full when trying to put this nut back on.
6) Disconnect the ground wire that goes from the engine to the engine bay wall at the bay wall using 10mm socket and a u
7) Remove the wiring harness from the alternator. It is a really tight fit but you will need to push the top of the connector from the back of the car towards the front to disengage the tab.
8) Pop the wire connector that holds the cables running down on the side of the alternator so you will be able to slide it out
of the way.
9) Remove the two 10mm bolts that hold on the antifreeze reservoir, lift it up and set it to the left of the main radiator hose.
10) Remove the top bolt using a 14mm socket from alternator.
11) Loosen the bottom bolt so you can turn it by hand but DO NOT REMOVE IT. I learned this lesson the hard way. The alternator jammed up against the air conditioner line coming out of the top of the compressor and took along time to get the bottom hole aligned so I could free the alternator.
12) There is a pain in the *** nut (PIAN) on a bracket which sticks off the back of the alternator. It is connected to a stud on the engine block. There are two studs there. The top stud connects the exhaust manifold to the engine. The one below it is the PIAN. I used a 12mm deep socket and a 3" extension to get at it. You may want to put a piece of electrical tape in the end of the socket to hold the PIAN in the socket so you can pull it off and not have to search for the nut.
13) Free the top of the alternator from top mount by pushing it down until the ears clear the mount.
14) Remove the bottom bolt.
15) Pull the alternator towards the left side of the car to clear the back stud. Wiggle and twist it forward towards the radiator. Pull it up by the pulley and out of the car.
16) Remove the bracket which the PIAN attaches and put it on the new alternator.
17) Remove the side bracket from the old alternator and put it on the new one.
18) Install the new alternator by reversing the procedure.
NOTES:
A piece or 2 of electrical tape in the socket will hold the nuts in the sock so you can screw them in.
A piece of electrical tape around the universal joint socket will stiffen it up the u joint when trying to reinstall a nut.
When you are done check the system and make sure it is putting out enough to charge your battery.
of the way.
NOTES:
Wire
It is either the alternator cable or the engime ground wire. The alternator cable attaches to stud on the back of alternator. The engine ground strap attaches to the engine wall using a 10mm socket. Steps 6 and 7 in my previous post. That alternator is a pain in the a$$ to get change. I feel your pain.
Elroyce,
This is the Connector. It plugs in somewhere. It has a press release on the side like The other connections. Def doesn’t bolt into the block for a ground and it’s too small for the alternator.
