2007 GS 350 Door Hinge Problem
Old 03-14-14, 05:47 PM
Brolic
Brolic's Avatar
I have the same exact problem with my car. Both my rear doors are really hard to shut.
Old 03-14-14, 05:53 PM
XxGoKoUxX
XxGoKoUxX's Avatar
drill and stop and drill and stop until you feel you're in the second piece of metal behind the hinge.
Old 03-14-14, 06:11 PM
07LXgs350
07LXgs350's Avatar
what about it rusting where you drilled it?
Old 03-15-14, 01:13 AM
ibidu1
ibidu1's Avatar
A better solution drill it, tap it, put a zerk fitting pump grease into it. But that maybe over kill
Old 03-15-14, 01:48 AM
XxGoKoUxX
XxGoKoUxX's Avatar
like that?
Old 03-15-14, 06:42 AM
alchemist
alchemist's Avatar
What about adding a rubber plug to the drilled hole?
Old 03-15-14, 09:41 AM
ibidu1
ibidu1's Avatar
No! On the side where the drilled hole is located, tap threads and screw in a zerk fitting to pump in grease.
Old 03-15-14, 03:11 PM
07LXgs350
07LXgs350's Avatar
Possible...can you show me which one your thinking of using?
Old 03-15-14, 03:57 PM
alchemist
alchemist's Avatar
Like the one used on bike frames...
2007-2008 Suzuki GSXR 1000 Rubber Frame Fairings Plugs Set Motorcycle : Amazon.com : Automotive 2007-2008 Suzuki GSXR 1000 Rubber Frame Fairings Plugs Set Motorcycle : Amazon.com : Automotive
Old 04-12-14, 12:23 PM
Stoodo
Stoodo's Avatar
Has anyone else tried this? Was it worth the effort?
Old 04-12-14, 08:47 PM
e-man
e-man's Avatar
2006 GS430 with 84k miles. Out of nowhere, this just happened to my rear passenger door. My car is CPO, but I just read that hinges are not covered. WTH? Let me make sure I understand this. The car is certified against major things going wrong with it, but my passengers can't ride along because they can't get into the backseat. How is it that a malfunctioning door isn't covered by CPO?
Is the drill fix really that easy of a fix?
Old 04-15-14, 12:25 PM
e-man
e-man's Avatar
Can someone please post the pictures back up? They seem to have disappeared.
Old 04-15-14, 01:34 PM
pman6
pman6's Avatar
Look at that rust. I don't think a rubber plug would help. It's still bare metal.
Old 04-15-14, 06:16 PM
BinaryJay
BinaryJay's Avatar
Rust proofing outfits drill all sorts of holes in these areas regularly, they just soak some rubber plugs in the rust proofing solution. I have never seen rust form from these holes and I can't see how it could get regularly wet in the first place. Open your door after it's been raining, the door hinges aren't wet.
I've got holes drilled all over from when I used to do rust proofing, I decided to stop bothering a few years ago as it makes such a mess and I have an interlock driveway. Those plugged holes aren't rusting.
Old 04-15-14, 07:46 PM
lexster68
lexster68's Avatar
No rust on the drilled hole on my door hinge. My buddy advise me to lube it whenever the door feels heavy to close again. The other solution would be to change the door hinges which means taking apart your fender to get to the door. This is the best and most cost effective way.
Quick Reply: 2007 GS 350 Door Hinge Problem
