Inside door handle not working
Old 09-15-13, 08:53 AM
Dons07
Dons07's Avatar
Default Inside door handle not working
I have an 07 GS 350 and the inside passenger front door handle stopped working. It will still open from the outside, but not inside. Has anyone else had this problem, and is there a simple fix for it?
Old 09-15-13, 08:56 AM
ibidu1
ibidu1's Avatar
Have you checked to see if it has a child safety lever on the side edge of the door?
Old 09-15-13, 08:57 AM
Dons07
Dons07's Avatar
No, I'll check that right now.
Old 09-15-13, 09:16 AM
Dons07
Dons07's Avatar
Only on the rear doors. Nothing on the front.
Old 09-15-13, 09:25 AM
BinaryJay
BinaryJay's Avatar
Easiest thing to do is just take the door panel off and look. It's only one or two (?) screws and then literally pull off... legos are held together more securely.
Old 09-15-13, 11:01 AM
XxGoKoUxX
XxGoKoUxX's Avatar
in your door handle, tape a small flathead, and pry open the cap under the flathead, there is one screw there, now in the middle of your door is a led light (CENTER of the door panel) pop it open with the flathead again, there's another screw there. It's preferential how to pull the door panel, I just pull and slide up.....
I think you either broke the plastic to the door handly holding the cable (which is really hard to break) or it just broke loose.
GL OP!
Old 09-15-13, 04:47 PM
BinaryJay
BinaryJay's Avatar
GL OP!
Yeah he's right it's two, it's been a while since I did it... but I did it to both rear doors when somehow one day both of the windows back there came off their tracks (I'm still suspicious about how that happened...) and I had to reseat the glass and put the rails back together. Getting the door off is really fast... like, it makes you wonder why these cars don't squeak an rattle 10 times more than they already do.
Old 10-03-13, 04:23 PM
Dons07
Dons07's Avatar
Took the door panel off and couldn't find anything. Put it back together and it worked about 3 times and quit. Did this about 5 times and keep getting the same thing. Can't figure this out to save my life!
Old 10-03-13, 07:34 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Could you take very detailed pictures of the door handles before disconnecting the two cables (lock and door opener cable)? Then disconnect the cables, take detailed pictures of the slots. You said they worked 3 times and quit...... i'm assuming your placeholder is broken for the cables or the ports on the OTHER end of the cables broke.
Old 10-03-13, 10:11 PM
ibidu1
ibidu1's Avatar
I wonder if it has to do with the actual lock mechanism
Helogadget
07-01-15 03:12 AM
vinsonF
IS - 1st Gen (2001-2005)
05-03-15 03:29 PM
BrandonLs
08-05-10 07:06 AM
linx
02-01-09 04:24 AM
mr nut
SC- 1st Gen (1992-2000)
12
09-25-07 05:37 PM
Quick Reply: Inside door handle not working
