Brake Master Cylinder burping noise
Old 04-14-13, 08:49 PM
njumongkol
njumongkol's Avatar
Default Brake Master Cylinder burping noise
Help Please..
My brake master cylinder is making a burping noise every time i press n hold the brakes. Do you guys think I have air in my lines? I recently changed my rear pads, but i didn't bleed it.. Any ideas would help. Thanks.
Old 04-16-13, 08:52 AM
morganc
morganc's Avatar
Based on the symptom that you're describing, it's quite possible.
It is not necessary to bleed your brakes after a pad change, unless you change calipers, opened bleeder fittings or your fluid is not its rich golden colour anymore. I would recommend having the system completely bled, because it never hurts to have nice, new fluid in your lines.
The other question you have to ask yourself is; is the brake pedal firm, or does it feel mushy and can bottom out? If you have a loss of braking power and/or your pedal is very soft and bottoms out, then you could very well have air in the lines.
Old 04-16-13, 08:54 AM
morganc
morganc's Avatar
I also don't know if your car has the ECB (I have a gs450h and it does). If this is the case, then the electric vacuum pump makes lots of funny noises I find.
SvenKivi
GS - 1st Gen (1993-1997)
10-10-16 01:53 PM
Azhar22
Suspension and Brakes
01-12-14 07:55 AM
ghuns
06-24-13 01:36 AM
phamxOC
17
07-20-11 12:17 PM
vj3
10-02-09 07:18 PM
Quick Reply: Brake Master Cylinder burping noise
