Help: Battery disconnect,windows crazy
Old 04-10-13, 12:53 PM
Chaos236
Chaos236's Avatar
Default Help: Battery disconnect,windows crazy
I disconnected the battery and upon reconnecting it my sunroof and windows are not functioning as before.
Thank you.
Old 04-10-13, 01:12 PM
c-low
c-low's Avatar
the door windows you have to go to each door hold down the button till it goes all the way down then hold the button goes all the way up and HOLD the button up for 5 seconds AFTER the window has already gone all the way up. do it to each door button.
hope this helps
Old 04-10-13, 01:14 PM
morganc
morganc's Avatar
You have to do a reinitialization of the windows and the moon roof.
Windows: With the ignition ON, go to each window and press down (hold) on the window button and keep holding it for about 3 secs after it bottoms, then hold the switch UP until it closes and hold for about 3 secs. This has to be done at each window, not simply from the driver's switch pad.
Moonroof:
Turn the power switch ON (IG).
If the sliding roof is opened, close it fully.
Push the SLIDE CLOSE switch or TILT UP switch, making the sliding roof operation as follows:
Tilt up → Approximately 1 second → tilt down → slide open → slide close
Sliding roof stops at the fully closed position.
Old 04-10-13, 01:30 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
You just made a sticky... cause its at least 2 times a month this happens.
Originally Posted by morganc
You have to do ......
Old 04-10-13, 01:39 PM
IXI187IXI
IXI187IXI's Avatar
Click Me & Click Me
Old 04-11-13, 05:18 AM
Chaos236
Chaos236's Avatar
Worked, thank you.
tomr51
09-25-17 01:02 PM
scout356
03-20-15 12:56 PM
Machog
IS C
04-29-14 02:59 PM
foe84
12-27-12 05:24 PM
mercurymet
IS F (2008-2014)
04-15-11 04:17 AM
Quick Reply: Help: Battery disconnect,windows crazy
