TPMS with bad valve core please help..
Old 01-29-13, 09:44 AM
MnGs3xx
MnGs3xx's Avatar
Default TPMS with bad valve core please help..
So I went to put air in my tires because my low tire pressure light was on so after I put air in the tire the valve core was making a hiding noise and turns out its leaking from the valve core I put a brand new one in and still a slow leak it seams to be the thread and lexus quoted me a new sensor and reprogramming for over 300 any ideas on what I can do, I was thinking of put some Teflon tape or some kind of sealer on the threads to make a better seal thanks
Old 01-29-13, 10:59 AM
neurocity
Neu`roc´i`ty
neurocity's Avatar
http://lexus.sewellparts.com/accesso...2008/4529.html
$85 from Sewell... just go to your local Discount tire for the swap and programming.
Old 01-29-13, 07:07 PM
rld14
rld14's Avatar
I have a similar problem with mine, they hold air and will take air but unscrewing the cores for tire removal (deflation) isn't going to work as they're corroded.
My solution, last time I changed tires, was to drill holes in the old tires. Not your issue but it might help someone.
Old 01-29-13, 07:29 PM
ibidu1
ibidu1's Avatar
Take it to any tire shop they sell rebuild kits.
Or you can buy them off ebay
http://www.ebay.com/itm/TIRE-PRESSUR...102a41&vxp=mtr
Old 01-30-13, 06:22 AM
TriniGS
TriniGS's Avatar
YEp best bet is to buy one from ebay or even better buy a set.
Old 06-04-13, 04:59 PM
filmteknik
filmteknik's Avatar
Are the valve cores standard or different for TPMS?
Steve
McCoy64
ES - 6th Gen (2013-2018)
04-02-18 07:12 AM
shoebopper
05-02-11 12:44 PM
MVB
01-12-11 10:40 AM
jones1950
02-09-10 04:53 PM
bobbynoise
09-03-09 04:27 PM
Quick Reply: TPMS with bad valve core please help..
