Should I write up a DIY for changing tranny fluid?
#33
https://www.clublexus.com/forums/gs-...sion-info.html
For fluid, stick with Toyota WS ATF or BG Product's ATF - there's an additive in the link above which may be endorsed or suitable, you'd need to enquire to find out for sure.
#35
Filter and gasket.
#37
#38
I am about to do it, so the filter is outside and easy access?
And how many quarts it uses, cause the dealer told me only something like 6 quarts.
With those questions solved, then it is pay time LOL
#40
Performed Repair
Fill Amount
Transmission oil pan and drain plug removal
1.4 liters (1.48 US qts, 1.23 Imp. qts)
Transmission valve body removal
3.5 liters (3.70 US qts, 3.08 Imp. qts)
Torque converter removal
4.7 liters (4.97 US qts, 4.14 Imp. qts)
advice from me lexus tech BECAREFUL DOING TRANSMISSION SERVICES.TO PROPERLY TEST YOUR OIL LEVEL YOUR CAR MUST BE AT 115* DEGREES AND PULL THE CHECK TUBE FROM UNDER THE OIL PAN. IF YOU DO NOT HAVE A TEMP GUAGE IT MUST BE DONE BY THE TRANMISSION ECU. IF YOU HAVE IT IMPROPERLY FILLED IT WILL RESULT IN IMMEDIATE TRANSMISSION DAMAGE.
this write up better be good.
Fill Amount
#44
Advice from me lexus tech BECAREFUL DOING TRANSMISSION SERVICES.TO PROPERLY TEST YOUR OIL LEVEL YOUR CAR MUST BE AT 115* DEGREES AND PULL THE CHECK TUBE FROM UNDER THE OIL PAN. IF YOU DO NOT HAVE A TEMP GUAGE IT MUST BE DONE BY THE TRANMISSION ECU. IF YOU HAVE IT IMPROPERLY FILLED IT WILL RESULT IN IMMEDIATE TRANSMISSION DAMAGE.
I researched this back when my car had 60,000 miles on it and I found exactly what is quoted here. That's when I decided to have the dealer do it. With 170,000 miles on my 2007 GS350, I will have the dealer perform its third transmission flush at 180,000. The transmission shifts so smooth after its done.
runningox
04-05-09 08:10 AM
ridedumped
07-16-06 05:02 PM
