Anybody have an LSD on their 3GS
Old 10-20-12, 06:56 PM
Ziggy716
Ziggy716's Avatar
Default Anybody have an LSD on their 3GS
Have not ran across anything in this forum about any members having an LSD equipped car yet.
LSD (Limited Slip Differential)
Old 10-20-12, 07:01 PM
Ziggy716
Ziggy716's Avatar
I'll have pics of me in a big ditch here shortly cause i did not have LSD to get me out.
Old 10-20-12, 08:51 PM
XxGoKoUxX
Forum Moderator
XxGoKoUxX's Avatar
heh, 3GS? Only LSD-equipped models are the AWD..... I've been doing some comparisons and so far I believe the Supra's rear diff is swappable with our 3GS pumpkin.... Dont quote me on that as I haven't had the full unit in front of me. LSD is very attainable though, you can even use the Supra's complete rear differential I believe, all you MIGHT have to do is get a custom driveshaft made (if they are not compatible).
Old 10-21-12, 11:26 AM
Stormforge
executive matchup
Stormforge's Avatar
Tom's have LSD for the 3GS. In fact, I was contemplating about picking one up a couple of years ago, but decided there wasn't much gain in doing the mod.
Application list in link below:
http://www.tomsracing.co.jp/products....php?mprID=286
See my discussion about LSD below:
https://www.clublexus.com/forums/gs-...rth-doing.html
Old 10-21-12, 01:49 PM
designo
designo's Avatar
Hmmmm, my GS460 is equipped with Limited Slip Diffs
Old 10-25-12, 05:34 PM
LexFather
Guest
Posts: n/a
^^^ Really, had no idea!
I know of the Tom's one...i don't really push the GS like that so no real use for me. Was a big mod to do with the 2GS though.
Old 10-25-12, 09:37 PM
XxGoKoUxX
Forum Moderator
XxGoKoUxX's Avatar
Nice find! I did not know this!! That means I can still keep my same final drive and get LSD powar!
Really???? Lucky
Old 10-26-12, 06:26 PM
Ziggy716
Ziggy716's Avatar
Here's the pics.[ATTACH]Anybody have an LSD on their 3GS-ziggy-s-iphone-10-26-12-144.jpg[/ATTACH]
Attached Thumbnails Anybody have an LSD on their 3GS-ziggy-s-iphone-10-26-12-133.jpg
Old 10-26-12, 11:49 PM
designo
designo's Avatar
Ouch, you ok?
Old 10-27-12, 12:43 PM
Ziggy716
Ziggy716's Avatar
Ouch, you ok?
I'm alright, the car isn't. Going to Lexus this Wednesday for suspension, allignment, and coffee.
Old 10-27-12, 01:43 PM
3rdGen350
3rdGen350's Avatar
Damn sucks
Old 10-28-12, 03:55 AM
XxGoKoUxX
Forum Moderator
XxGoKoUxX's Avatar
He looks okay, he seems to be smiling and giving that good ole peace sign
Old 10-30-12, 09:29 PM
slowdiver
slowdiver's Avatar
Has anyone actually done this on CL yet?
I'm taking off my 2nd Gen diff that has a Supra Torsen LSD in it along with 4.27 gears. I'd love to drop it into the 3rd Gen diff. I doubt the entire differential or pumpkin is a direct swap for the 3rd Gen GS but maybe the LSD will fit. I'm going to email KAAZ USA and see if they can tell me.
Does anyone know what the stock gear ratio is for the 3rd Gen GS350? Specfically the '08?
Old 10-30-12, 11:40 PM
mr nut
mr nut's Avatar
I am not sure if this means anything, but the IS250/350 guys use the IS300 torsen lsd units in their cars.
I know the 3rd gen GS shares alot of parts with the 2nd gen IS.
So maybe it is possible that it will work on the 3rd gen GS as well?
Old 01-15-13, 07:30 AM
slowdiver
slowdiver's Avatar
So I confirmed that the 2nd Gen GS/SC pumpkin is NOT a direct bolt on for the 3rd Gen GS.
I'm going over to KAAZ today to see if I can drop my Torsen LSD into the existing diff. I may also do the 4.27 gear swap as well. From the little research I have done, I believe the 3rd Gen GS has a gear ratio of 3.76. I believe the IS350 has a gear ratio of 4.08. If you guys can confirm this for me it would be greatly appreciated.
There is a significant difference in low end torque with the lower gear ratio(4.27). The LSD is much harder to tell a difference unless you are tracking your car. If today's project doesn't work out, I'll most likely be searching for an IS350 pumpkin. Again, if you guys can source the data on all gear ratios by year for the 3rd Gen GS/IS it would be nice to have this.
Quick Reply: Anybody have an LSD on their 3GS
