Build Threads Details on Club Lexus 3GS owner vehicles
Build Log
Old 10-28-12, 04:16 AM
  #31
XxGoKoUxX
Forum Moderator
XxGoKoUxX's Avatar
Originally Posted by JDMMUNKY
i thought the transmission is sealed ?
I believe when they say sealed, they mean the transmission doesn't have a dipstick for monitoring because they use a "longer maintanence interval" oil.
In general, every trans mission, sealed or not still has bolts and stuff in there, otherwise there's no way to service it if so there happens to be a problem with the trans.
Old 10-28-12, 03:39 PM
  #32
JDMMUNKY
JDMMUNKY's Avatar
they told last time I couldnt service it
Old 10-28-12, 08:39 PM
  #33
kuWuPt
kuWuPt's Avatar
Originally Posted by lilSCsteve
kuWuPt, smart move with the maintenance first...something I usually do before any comestic stuff. Which gives me a piece of mind, plus as you stated saves the "wallet". Now to the meat and potatoes...I like what you did with the paint stuff and air-FTW! so what's next for your GS? Another big up to a fellow NCarolinian!
Thanks man, always did maintenance first which is why my builds always take longer but as you stated, piece of mind is a big plus. Honestly I've been waiting for my wheels to come in so it can get fitted to the car, fender work etc. Then it needs a paint job.
Transmission on the GS430 is classified sealed because there is no dipstick to check fluid levels etc. However there is a drain and fill bolt on the transmission. I dropped the pan cleaned it, changed filter, filled the same amount of fluid drained from the pan back into the transmission via the fill hole and then did a full flush using a transmission flush machine.
Old 10-28-12, 09:15 PM
  #34
JDMMUNKY
JDMMUNKY's Avatar
Do you know the part number for transmission filter
Old 10-28-12, 09:18 PM
  #35
ISFPOWER
ISFPOWER's Avatar
nice car AJ, what happened to your old gs?
Old 10-28-12, 10:24 PM
  #36
kuWuPt
kuWuPt's Avatar
I have to dig it up but will post it up once I find it.
Thanks man, well the old GS got totaled in May.
btw where in NC are you and have we met? I met a couple of people with an ISF here and I'm horrible with names.
Old 10-28-12, 10:39 PM
  #37
ISFPOWER
ISFPOWER's Avatar
dammmmmmn. it was so clean. Its me Andrew with the black 350z, fool. lol
Old 10-28-12, 11:33 PM
  #38
JDMMUNKY
JDMMUNKY's Avatar
Thanks you trying to do it this week
Old 10-29-12, 10:53 AM
  #39
kuWuPt
kuWuPt's Avatar
damn foo stepping up the game!! Funny thing is I was talking to Aaron and he said you wanted to get some fender work done, and now it makes sense. Get up with me cause he is coming to Raleigh to get a car done for me so he wants to do yours at the same time. Welcome to the Lexus family and I have the Techstream system if you want to re-program any of the car's features.
I would man but I'm in NY and kinda stuck till the storm passes so not sure. But I'll try to get it for you ASAP.
Old 10-29-12, 04:32 PM
  #40
ISFPOWER
ISFPOWER's Avatar
thanks man, i'll PM you my number, please call me when he comes. i hope it's this week.
i'll look up what techstream can do and i'll hit you up.
Old 12-24-12, 12:57 AM
  #41
kuWuPt
kuWuPt's Avatar
UPDATED - Post #2
Old 01-20-13, 12:36 AM
  #42
kuWuPt
kuWuPt's Avatar
The LS460 has the third brake light integrated into the roof spoiler, very subtle and a nice detail on the car. I wanted a similar mod ever since I saw it. Although not as clean as the LS below is my attempt at integrating the third brake light into the spoiler.
Started off with ordering a roof spoiler which I thought was subtle enough to add the definition without being too bold. Also I ordered a fiberglass wing and not urethane, solely for modification purposes.
A slight cleanup of the lines to make it a little smoother and fitment was on point. An outline of the third brake light was made and transferred onto the spoiler. The outline was cut and trimmed to fit the third brake light.
Also a small hole was drilled in the corner of the wing to run the power wire, not visible once on the car. Fuzor was used to fill in the gaps and hold the third brake light in place. Also the drilled hole for the wire was filled in with fuzor as well.
After cure time, verified again that the LED's are working and continued to smooth the fuzor to match the lines of the wing and was primed.
The whole wing was then sanded smooth and primed again after fixing more manufacturing defects and went in for paint to Jeremy @ The Body Shop. I would like to thank him at this point for doing an awesome job on it.
Will post pics on the vehicle when everything else falls into place. Till then the parts pile up continues.
Add us on facebook: Flawless Fitment.
Write up: Flawless Fitment
Old 01-20-13, 02:19 AM
  #43
AustinSBP
AustinSBP's Avatar
a damn good job
Old 01-20-13, 08:46 AM
  #44
SoCal_450h
SoCal_450h's Avatar
how did you run the wire? did you drill the roof?
Old 01-20-13, 09:41 AM
  #45
swtjlsy
swtjlsy's Avatar
he must have ran it down the roof molding in through the trunk
Quick Reply: Build Log
